Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Top of my sub zero isn't cold enough and freezer is fine...I had this problem once before and solution was simple...water runs up to frig and it froze so I think I had to turn off frig so it could melt....I forgot if I turn off the freezer too..I don't think I did but I've forgotten...Does this sound familiar????
  • 4,102 Answers
Hi, you can sometimes get away with just turning the fridge off so i would try that first, give it enough to melt and then switch it back on and see what happens, but if after doing that its still got the same problem then it will need it all turning off, usually just turning the fridge off for few hours solves the problem, it does help if you turn the freezer down a bit as well but remember to turn it back up after else you will have soggy food.
so give the above a try it usually works but turning the freezer down a bit usually saves you turning the freezer off so give that a try and see how you get on ok
let me know if you need further assistance ok
plz rate this solution as a lot of people cant be bothered than i get a whole page or 5 pages of unrated posts, thanks
Posted on Aug 30, 2010
I have a Sub Zero 690 (June 1999 model). The frig size light switch went out. We popped it out to test to see if it had continuity (it didn't). We put it back in and planned to call service guy to...
remove the top light cover,hold in the other switch that's next to the light switch,the fan should turn on,it sounds like the fan isn't working,go back up top,remove the metal cover that's above the switches and see if you knocked the wire off of the fan switch.why can't you see the control panel?did it go out when you touched the light switch?
Sep 04, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero Frig not getting cold. Freezer part works fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Refrigerators
Sub-Zero side by side freezer working fine frig set to 38 and is up to 50 and will not cool anything I can do?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Freezer reads 00 but the frig section reads 57....where is the line to the frig...seems that is plugged
i coud not see the model # of your sub zero . some models like th 550 / 650 use 2 compresors . freezer system maybe ok when fresh food is not . . first thing to do is ck the cond coil up on top and clean it and mk cure the fan is cooling the coil . you moy have a cold control failure . and the fresh food comp may be low on gas . these are the most common cause for your problem .. mm feed back pls ..
Oct 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub Zero side by side frig. side not cooling. Freezer works fine
There is a fan inside the freezer and possibly the fridge. It circulates the cold evenly throughout the unit. The fan may shut off with the door open so hold the door switch in to see if you hear the fan. It's behind the rear cover on the inside.
Sep 11, 2009 | Refrigerators
Sub zero unit 501R is not staying cold.
you need to get its dial unit changed. if somehow u can fix it urself, then all the best...
Aug 17, 2009 | Now Hear This Classic Absolute Zero Main /...
Sub Zero 611F "vacuum condenser" warning persists, unit not 100%
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jun 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
Top shelf of old sub-zero refigerator 60 degrees, bottom shelf OK
u may have a defrost problem it would be worth paying for the service call if something simple like defrost or a fan would still be more than 200 but worth it
Mar 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero model#3211-rfd, side by side, freezer working fine, but refrigerator not cold enough, alwaus stays 40F, even i turn to the max.
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Jul 30, 2008 | Sub-Zero Refrigerators
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
77 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
