Question about Seiko DPU 414 Matrix Printer
I have windows vista and when i go to install the printer i cant find this model dpu 414 help?
  • 11,800 Answers
This printer isn't supported in Vista. All you can do is to install a Virtual machine, XP on it and the printer in that XP.
Posted on Aug 30, 2010
This printer is connected to a device that on occasion will print data in the middle of the line with incorrect values when compared to the display. When the device is told to reprint, the data is not...
please check the DATA cable and printer driver installed in the system. these are two things often responsible for junk printing.. what kind of printer iit is ? laser ? inkjet or Dot matrix?
Sep 26, 2013 | Seiko DPU 414 Matrix Printer
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
I have a DPU-414 Thermal printer that just won't get dark enough. I have already changed the switch settings to its highest density 121%....
Access and clean the area where the paper runs over the heating/printing element. This area picks up foreign substances and bakes them so that the paper no longer makes proper contact with the print head. Use something like an alcohol based solvent to remove any build-up in this area.
May 03, 2011 | Seiko DPU 414 Matrix Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
What tipe of cable can you use for a usb input?
Your printer has the older style "Parallel Port" (IEEE1284) and Serial RS-232C. You should use the parallel cable to connect with your computer. If your PC does not have a parallel port, then you can either install one on an expansion card for about $10-15, or even easier you can get a converter cable which will allow you to plug right into your computer's USB port. You can get one like this for about $10. Here is an example: http://www.newegg.com/Product/Product.aspx?Item=N82E16812156005&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Cables-_-Sabrent-_-12156005
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Dec 05, 2010 | Seiko DPU 414 Matrix Printer
Windows vista home premium with service pack 1
You need to download a driver for the printer. Whats the name and model of the printer?
Mar 04, 2009 | Microsoft Windows Vista Home Premium with...
HP PSC 1410 can support Window Vista ??
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441115&cc=nz&lc=en&dlc=en&product=441115&dlc=en&lang=en
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808551&cc=nz&lc=en&dlc=en&product=441115&dlc=en&lang=en
Dec 06, 2007 | HP PSC 1410 All-In-One InkJet Printer
Seiko DPU 414 Matrix Printer Logo
153 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
