Question about LG DU-42PX12XC 42 in. Plasma HDTV
1 Inch wide vertical lines (2 on each side, 4 different colors). How do I correct this?
  • 443 Answers
Bad panel, call LG and see if they will replace the panel for you!
GOOD LUCK !
Posted on Aug 30, 2010
Sony KDL40EX400 has (2) 2 inch wide vertical color bars about 4 inches from the left side of the screen. Purchased July 2010
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | Sony KDL40EX400 40 in. HD-Ready TV
Aug 22, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical line
replace the vertical ic chip
Feb 14, 2010 | Panasonic TH-42PX60U Television
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Polaroid FLM-3228
cheak cables gold leads only hi end ground antenna good power strips get any magnets stuff away from it interfence ok
Feb 12, 2008 | Polaroid FLM-2632 Television
LG DU-42PX12XC 42 in. Plasma HDTV Logo
55 people viewed this question
Computer Repairing
Computer Repairing
