Question about Canon CanoScan LiDE 500F Flatbed Scanner
Black line down middle of scan
I am trying to scan a document in color and I keep getting a solid black line down the middle of the page. Can you tell me if there is something I need to clean or do we need to get another scanner?
  • 1 more comment
  • Rhonda Cooley May 08, 2008
    Here's an example of the black line that is printing on my scanned documents.
    MrsCood
  • Ronald Priestley Jun 04, 2008
    I have the same line down middle of page problem with my Canon MP830 but it occurs during printing. Does this also mean my element is shot and that I need to replace the printer? Thanks, Ron
  • Anonymous May 11, 2010
    Does it scan ok in Black and white?
Well I hate to give out bad news but if that line is in the exact same location on every scan it means that the element (the scanning light) has failed. Sorry that I could not earn a FixYa for you. If you need to replace the scanner I have had excellent luck with Epson scanners. Here is a link to a few on Amazon.com for refrence.
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps
&field-keywords=epson+scanner&x=0&y=0
Just copy the link and paste it into your web browser. there are also some very good all in one options. I have had this one for a year and it works well:
http://www.amazon.com/C7280-Photosmart-All-Printer-CC567A
/dp/B000UY6M2G/ref=pd_bbs_sr_4?ie=UTF8&s=office-products
&qid=1210270089&sr=8-4
Hope that was at least helpful.
Take Care,
-WN
Posted on May 08, 2008
No, I still get a black line. I also tried the grayscale too but I still get the line.
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Solid black line down the document when scanning
are you using the autofeeder to feed your documents?
if yes, open the top cover and clean both glasses (big and small).
and take the drum out, move the blue panel to clean up your drum.
after that should be working fine.
May 11, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP J5780 All in one printer
Once try to make a scan and if we are getting line even while scanning. Then perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01129408&cc=us&lc=en&dlc=en&product=3301296
Directly go to step three and then try to make a copy.
If the issue still persists then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Now try to make a copy and check for the result. If the issue still persists then reset the all-in-one.
  1. Unplug the power cord from the product.
  2. Press and hold # and 6 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Jun 05, 2008 | HP Officejet J5780 All-In-One InkJet...
Thick Black Line in Middle of Printed Document!
Your question might best be answered at the website below
http://www.canon.co.uk/Support/index.asp
They have technical support plus drivers and other odds and ends concerning your equipment
Feb 22, 2008 | Computers & Internet
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Canon CanoScan LiDE 500F Flatbed Scanner Logo
3,058 people viewed this question
old marine
old marine
