Question about HP LaserJet 3330 All-In-One Printer
All of my keys are in chinese i need to know which button is copy and print
  • HP Master
  • 11,800 Answers
Here's the user manual for it
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl11368/bpl11368.pdf
Posted on Aug 30, 2010
I have a samsung hf 1000 which speaks to me in chinese but i need it in english, any ideas please?
I did this to my HF1000 Handsfree device this evening as I had mine in chinese language as well today.
Power up the unit the vioce will say power on, wait for silence then push and hold the Call button, the unit will speak the pairing instructions including the pair code of 0000. regardless of the language the voice will repeat the number four times, so even thought you might not understand it, you will hear the number repeat....
After a brief silence period, press and hold the call button again, the next announcement is the language selection menu. After the announcement press the Volume + (plus) button to change the langauge, this announcement is quite long. Wait for each announcement (they are maybe two full sentences long).
Press the plus (+) Volume button to again to change to the next language, wait the appropriate length of time and press the plus Volume key again, for the next language....
Chinese language is directly after English, and so you need to go throught the key press sequence about I think five times. English, then Chinese, Italian, Spanish then German, is the sequence I believe.
Hope this helps!
Oct 08, 2011 | Samsung HF1000 Bluetooth Headset
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
The print screen button doesn't seem to work....
The PRINT SCREEN key (prt sc) copy the screen from your pc at the clipboard. After pressing this key you have to start an image editor software (or Microsoft Word) and paste the copied image.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 01, 2011 | Computers & Internet
Reset drum
Hi there!
To reset the drum light you need to press the following keys in sequence with 4 seconds for the initial 4 keys
Step 1: You need to press "C" then please press the far left key ( called exposure mode key) then press the "C" key then the far left key once again.
So the sequence is -- C, far left, C, far left.
Note: Some model utilize two other initial codes, you might need to use one of those two alternate codes to get your display to go blank. The remainder of the procedure is absolutely the same.
The alternate codes are as follows: #, * , C, * or pound key ,star key, C, star key and also #, Interrupt key, C, Interrupt key.
If done correctly the display will go blank.
Then type in 24 as if you are going to print 24 copies of something.
Then press the "print" button.
Then type in 7 as if you are making 7 copies
Now press the print button once again.
You will now get flashing zero's on the display of the unit.
Turn the machine off and then on again and your drum light will be gone.
Sep 06, 2010 | Sharp AL-1651CS All-In-One Laser Printer
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
    The CE Access Number screen will appear.
  2. Enter 6789 and press Confirm.
  3. The top most area of the UI display will be reversed to let the user know that the mode has changed to the CE mode
  1. Enter the Diagnostic mode.
  2. From the Common Settings screen, select Image Quality Adjustment.
  3. Select Calibration.
  4. Select the button of the Screen Type to be calibrated, that is, Copy Job - Text, Copy Job - Photo, Print Job - Text, or Print Job - Photo.
  5. Press the Target button and then select the type of jobs to be calibrated, that is, Copy & Print Jobs, Copy Jobs Only, or Print Jobs Only.
  6. WC 72XX only: Load A4 paper in the Tray 5 (Bypass). Press Save.
    WC73XX only: Select a paper size and type using the paper supply button
  7. Press Start. The auto gradation routine will run and a message will display upon completion.
  8. Take the print from the output tray. Follow the instructions on the screen to complete the color correction.
Jan 15, 2010 | Xerox WorkCentre M-24 Color Copier
My multipass 370 printer won't print
Hi
MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printing problem
in China , I found certainly have secret society, it have
secret words and body langue or other things.it control the real society.
decipline and wealthy even women. it have out of the control of Chinese goverment . I think the whole world should know these information.
Aug 13, 2008 | Canon MX700 Office All-In-One InkJet...
Printer keep printing same job
Check you menu on the printer to ensure that under copies it says 1. It's easy to hit the keys when in the menu under copies one key minus and you now have 999.
Check the default number of copies at the print driver side (when you hit "file print") to make sure it says 1 also.
Hope that helps you.
Jul 22, 2008 | HP LaserJet 4 plus Printer
Chinese information
Had same problem, don't know why but here's how to fix it...
(1) Press the HOME button. Wait for about 5 seconds, select [pliers & screwdriver icon]i_settings4.jpg, and then press the OK button.
(2) Press the r_mark_s5.jpg[right cursor] button to select [sliders & levels icon]i_devicesettings6.jpg, then press the OK button.
(3) Press the [down cursor]d_mark_s7.jpg button four times, then press the OK button.
If the Bluetooth unit is connected to the machine, press the {down cursor]d_mark_s8.jpg button five times, and then press the OK button.
(4) Press the t_mark_sv9.jpg[up cursor] or [down cursor]d_mark_sw10.jpg button to select the language you want to be displayed, then press the OK button.
Mar 10, 2008 | Canon PIXMA MP810 All-In-One InkJet...
HP LaserJet 3330 All-In-One Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
