Goodmans hi, i just want to know how to reset my tv to factory settings pls help me; it is a goodmans gtv 42p4.
  • bazman May 08, 2008
    tried it but did not work!!! thanks for info though:)
  • dorty57 May 09, 2008
    cant adjust volume control, stuck at minimal volume
  • 558 Answers
Unplug it from the wall for 30 min that should run the capacitors down and reload presets in the tv
Posted on May 08, 2008
Factory reset tv
What model Goodmans TV?
Jul 20, 2013 | Goodmans Televison & Video
TV comes on to standby, but with record led flashing. pressing power on , power light turns green for 1 second, click from within unit, back to standby with record led flashing
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours).
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Televison & Video
Hi, we have a goodmans GTVL27W23HD that was left on standby for 6 days, now will not show the digi-box channel, just a blue screen, sound only on scart 1 any suggestions anyone? something re-setting...
Try to unplug everything and plug it back in at the correct order(without power). Then plug the power and into the items in the correct order and let them power on for about 5 minutes. With the blue screen that may take about 15-20 minutes.
Apr 19, 2008 | Televison & Video
Motevo gtv x3 touchscreen: I don't know how to set radio stations. Once I find a radio station I try to store it, but I don't have a clue how. Can someone explain it to me or tell me where I c
I just bought a used honda city that has this Motevo GTV-x3+ installed. I was successful in storing the channel using the remote. After I go into the radio section, I touch the "Scan" button on screen and once it pauses on a channel I like, I touch the "Scan" button again. This stops the tuner from moving on to the next channel. Next, using the remote I long press a number for example 1 and the channel is stored in the list on position 1.
Oct 22, 2012 | Motevo GTV-X3 - 6.2" Touchscreen...
GOODMANS LD3765D 37" HD READY ITS SOUNDS TINNY
Hello
Enter in this link, where you can download the user manual for your Goodmans Tv. It will give you all details about its settings..
http://safemanuals.com/brand-user-guide-instructions-owner-manual/GOODMANS
Nov 14, 2011 | Televison & Video
I have a goodmans, LD1540WD, 15 '' widescreen TV with freeview. Its my bedroom tv so doesn't get a lot of use. I've had it for about three years.Quite honestly it is the worse tv I have...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 06, 2017 | Goodmans Televison & Video
Need the Digihome PVR80 manual or GUSTB250IV pdf manual please..
As far as I have checked your Digihome PVR80 is the same model as the "Goodmans PVR80".
the Goodmans manual can be downloaded from their website as given below...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
http://www.goodmans.co.uk/content/ug...language=en-GB
Jun 15, 2011 | Televison & Video
Picture no sound
Reset the tv back to factory setting,by unplug,repluging it an hour later.Go in ur tv AUDIO setting reset it,now it back to factory setting,Should work,not than the tv Tuner board recieve the broscast signal boad is have problem must br replaced.
Jun 02, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Reset Default Settings
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (fa couple of hours at least or preferably overnight).
Alternately, pls check if you have "Zoom" enabled.
May 08, 2008 | Televison & Video
Reset tv to factory setup
Most current TV units can be reset to default factory settings by being unplug from the mains fro at least a couple of hours (or overnight).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Feb 19, 2008 | Televison & Video
Televison & Video Logo
429 people viewed this question
Top Televison & Video Experts
