Question about Fuji FinePix A500 Digital Camera
My camera says it has a focues error how do i fix it?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
I'm having problems with my casio exilim when i turn it on its not all the way focued and it sometime wont close.can you elp me
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Oct 19, 2010 | Cameras
I cant view the picture clearly while shooting and playback too.i was on a picnic 2wks back,and was taking pictures with my canon SD550 POWERSHOT CAMERA.. all of a sudden the display in the screen blurred...
There is a focuing ring with electromagnets on it, and it swivels to focus. When sand, dirt, lint, or dust works its way into the lens assembly, it can get stuck, failing to focus.
Spray some compressed air into the lens area to try to dislodge it. Then bump it gently if the compressed air doesn't work. Here is a list of things you can try for a jammed lens:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If these don't work, your focus ring is jammed and you will have to fix it or have it serviced. Get an estimate first, since the cost of repair often justifies buying a new camera.
Good luck, these tips might help you.
Aug 27, 2010 | Canon Cameras
Why has my hd lost its luster? not asclear, smoky picture. its a sony rear projectile tv hd 46in. model kp 46wt500
usually these tvs will need a tune up from time to time. You can try to push the flash focus button on the front and that will fix any minor misalignments, but to really fix it, it likely needs the crts focued and a convergence re-alignment. sonys are tricky, but if you feel savvy and want to dive in, let me know.
a tune up may run $50-150 from your local repair shop
Jun 14, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Canon Eos Rebel xti won't take a picture when zoomed in
Try a different lens just to check out the lens focus sensor. or put it in manual focus.
Sep 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Samsung S1050 -out of focus - beeps twice and switches off
The drop indicates that you have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung S1050 Digital Camera
Sigma 170-500 f5.6 not focuing at 500mm
I sent my 135-400 to these guys about 18 months ago- speedy service, and quite good rates :)
http://www.sigma-imaging-uk.com/
Mar 09, 2009 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Camera is not taking pictures
hello customer,
First check the batteries (are they fully charged, are they inserted correctly). Next connect the camera to an AC adapter (if available). Try to turn the camera back on. If it works, then try different batteries. If the camera is still not working, after checking the trouble shooting section in your camera manual, call the camera manufacturers support desk. Expecting your feedback. thank You.
Jul 09, 2008 | Nikon Coolpix 4200 Digital Camera
42h81 touch focus error
You can get one at the following link, they are not free but the tech support they offer with the manual purchase is free.
http://servicemanuals.vstore.ca/
May 28, 2008 | Toshiba 42H81 42" Rear Projection...
Canon EOS Rebel G
From the Canon Help Email - this worked for me: If you are using an EF series Canon lens, please remove the lens and clean the lens contacts with a pencil eraser. We also suggest that you remove the film and battery for 15 minutes; ensure that the battery has a full charge and reinstall. If the issue persists, we suggest testing the camera with a different EF series Canon lens. Should this persist with a different lens, then the camera body itself will need to be examined.
Jan 17, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Fuji FinePix A500 Digital Camera Logo
15 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
