Question about NorStar Meridian M7310 Phone
Nortel norstar m7310 phone caller id problems
I just had to move desks at work and my caller id doesn't work until after i pick up the phone. how do we fix this so I can see caller ID before?
thanks
  • 4 more comments
  • dbl1 May 08, 2008
    thanks for the message...
    my experts just left and did something because now it works.....
  • TimMer11 Jul 16, 2008
    We have the same problem as described above. I've tried everything and can't restore the caller ID display. The phone was moved, but we kept the same extension.
  • yvettehorne Aug 04, 2008
    The called ID only works after I pick up the phone. How do I get the caller ID to work before the phone is answered?
  • relax536 Aug 26, 2008
    I am new to this company and NorStar phone system. The extension numbers are on none of the phones how do I know who has what extension?
  • Anonymous Jan 21, 2009
    caller id doesn,t work till you pick the phone up
  • radio9898 Feb 23, 2009
    My caller ID on the Norstar/Meridian system is not working at all.
    My set models are the M7310
    Problem Solver:
  • 3 Answers
@relax536
to find out your phone's extension dial
Feature *0 Intercom
Posted on Mar 15, 2010
Did you change extension numbers? Or did your extension number move with you?
Posted on May 08, 2008
CANT GET CALLER ID TO WORK ON NORSTAR M7310 PHONE IS IT CAPABLE
This feature requires a class trunk card in the phone system to pass Caller ID.
Jan 17, 2013 | NorStar M7310 Corded Phone
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Display caller id before pickup
talk to your phone service provider.
May 09, 2009 | Office Equipment & Supplies
Can somebody help me in setting up caller ID on my Nortel Norstar M7310
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
that should do it providing you have caller id service though your local telco provider.
Mar 26, 2009 | NorStar Meridian M7310 Phone
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
How to setup caller id?
Have your tech look again. A keyword search of CALLER ID in the pdf should explain it all, especially page 158 of a 6.1 CICS manual.
You need 2 things to make it work. One is that your phone has to be ringing. Two is that Under Telco Features in programming for your set is a CALLER ID set which is No by default.
Of course, FEAT 811/812 will work after the fact.
Carl
Nov 13, 2008 | NorStar Meridian M7310 Phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Oct 25, 2007 | Lands Phones
NorStar Meridian M7310 Phone Logo
4,958 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
