Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
The water supply line to my frigidaire [ FRS6HR5JQ0 ] came off back of frig after being on for 2 yrs with no prob.And never been moved. Tried to put back on but seems after a few minutes water pressure builds up ih hose and pops it off. Like the water is getting stopped some where.
  • 1 more comment
  • farlinrandy Aug 30, 2010
    Hose came off inlet valve ,and it has been on there for almost 2 yrs. it has not been touched or moved at all.when i put back on it's good for about 5 minutes then u can feel pressure build up in the last 3inches of hose that goes into inlet,then pops of. before it comes off i was able to get water from dispenser.
    GOT IT!!!! THANK YOU. I was'nt putting brass insert into tube before i screwed it on and did'nt have tube pulled threw nut enough. Thanks again
    Thank you!!!
    President:
  • 670 Answers
What kind of material is the water supply line made of? Copper or plastic? The correct way to attach a copper line to a refrigerator is to slide the compression nut over the line, then slide the ferrule over the tube. Finger tighten the nut onto the water inlet. Then use two wrenches on attached to the inlet nut and the other to tighten the nut. If the nut is tight, there is no way for this to pop off since the ferrule and copper pipe deforms and becomes one as the nut is tighten.
If the water line is plastic, besides the compression nut and the ferrule you need an addition part which is the brass reinforcement. The brass reinforcement is a brass tube with a lip on the end. It is placed into the plastic water line before you tighten the water line compression nut. Make sure you have this brass reinforcement inserted in the plastic water line otherwise the water line can easily leak or pop off if the compression nut is not tight enough. Hope this helps you.
Posted on Aug 30, 2010
  • Stephen Lam Aug 30, 2010
    Glad you able to fix the problem! Thanks for using Fixya!
    Brigadier General:
  • 3,513 Answers
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
Frigidair Frig PHSC39EJSS. Ice is forming on freezer floor. I have already shut off the water supply for several days to see if it was coming from the ice maker and it still iced over. Also we...
Your condensate drain line is stopped up. Break the ice up off the freezer floor with a screwdriver handle. Turn off the refrigerator. Remove the back inside panel from the freezer. Break up the ice in the drip pan with a plastic handle. you can either heat up a wire with a torch and stick it in the drain to thaw the ice in the drain or set a hair dyer in the freezer until the ice melts in the drain. Then find a 4' piece of 3/8" tubing to stick in the drain and blow in the other end to remove any trash in the drain. you can use compressed air or weed eater line. anything that will clear the drain
Mar 24, 2011 | Frigidaire Refrigerators
I have a Frigidaire side by side frig, model FRS20ZKG. My supply inlet to the ice maker keeps freezing which after 2-3 cycles will not make any more ice because no water can make it to the tray. This...
The supply inlet to the ice maker is connected (via metal coupling) to the radiator-like-coils in the freezer which are actually hot and they keep the line from freezing. If this coupling is not connected close to a heat source, then the supply line can freeze as you are experiencing.
If possible reroute the supply line out of the freezer area
Sep 23, 2010 | Frigidaire Refrigerators
Water squirts out the back of my Kitchen Aid Superba where the water line enters the fridge. This happens when the ice maker tries to fill with water.
make sure that the water supply line is tight. the line that comes from the wall should be copper or stainless steel braided line. if it is the clear plastic line get rid of it as it is more prone to kink and leak especially at the points where the connections are made... another thing to check is where the supply line connects to the frig.. that is the solinoid valve and on the top is a blue or clear plastic cap and somtimes they will crack or have a small pin hole in them and will spray a very fine stream of water that is hard to see but can be felt on your finger tip.. pull out the frig and empty the ice tray and put it back in and close the freezer door or drawer and wait for the ice maker to call for water and have a bright flashlight ready, when it calles for water you will only have about 5-7 seconds to see where the leak is so make sure to feel around as well.; if your are replacing the ice maker supply line from the wall to the frig make sure to not over tighten the connection to the frig because it may cause that plastic cap to crack....I hope this helps....
Nov 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
I own a side by side black-n-stainless fridge and I bought a kit for the water/ice despenser, installed it as per instructions but not getting any water in the ice maker or out of the water. The water is...
If its got a filter under the frig. just hook your water to the house water line. If not then put a filter in the cabnet next to your frig. Or in a handy place to get to. And you will have to hold your water lever for a long time till all the air gets out of the line. there is a extra long hose you must fill up in your frig side. It is used to keep cold water ready to drink.
hope this is helpfull
Aug 12, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
282 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
