Question about GE Profile JTP56 Electric Double Oven
F7 error code
I have the dreaded F7 code on my GE Profile single oven. I see listed under your name you have the magic solution! Can you share some help? Thank you so much! Kathryn my ge double oven has f7 code that goes off. can unhook ribbon and plug back in and it will work for a while then it my kick off in middle of baking.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
Hi dadcandoo,
You can find my solution for the most common cause of the F7 problem at the following links:
http://www.fixya.com/howto/h155060-dreaded_f7_error
or
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have now shared my fix with over 1700 folks and most report success. It is simple and free. I hope that it works for you too. Please let me know at hutchipop@yahoo.com. Also, what is your model number, how old is your oven and where are you located? I am making a statistical study of this problem.
Regards,
Charlie Popeck, P.E.
Consulting Enginner
Posted on May 09, 2008
  • lvkidds Nov 30, 2014
    Thank you so much for your instructions. When I pulled the panel I noticed there were already two pieces of paper placed in the ribbon slot so apparently this oven has had this problem before (we purchased this house a year ago). I took the pieces of paper out and re-inserted them and then added the third piece between the ribbons at the point where it comes together and is slightly turned. So far so good and I'm hoping it continues to work. I'm just thankful this didn't happen last week when I was preparing our Thanksgiving meal! Thanks again.
I used the solution that some else had mentioned about putting a piece of paper between the backing plate and the ribbon where it goes thru to the the control panel.I did this about 3 or 4 days ago and its been working like a charm ever since. Thanks again for the insight.
Posted on May 12, 2008
2 Suggested Answers
SOURCE: F7 error code
Easy fix: Just carefully disconnect the ribbon from the slot, get a pensil eraser and use it on both side of the contacts, slide it back in and you are set.
Posted on Sep 04, 2008
Ge performance profile F7 error code
code f7 is a error code for self cleaning device
Aug 17, 2012 | Whirlpool RBS275PD Electric Single Oven
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
Ge profile convection oven giving error code F7. What parts do I need
Hi
Thanks for using FixYa. Error F7 means that the function pad button is stuck or the clock has gone bad. If you are unable to unstick the button then to resolve this issue you’ll have to replace the electronic range control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | GE Profile JTP18 Electric Single Oven
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
We are getting an F7 code on our display ..What is this?
Jun 07, 2009 | GE JRS06 Electric Single Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
Error message...
The F7 is intended to indicate a stuck START key. However, a design defect may cause a false indication. This can be corrected by adding insulation to the ribbon cable. You can find detailed instructions at my web site. Follow this link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
All of the above must be entered as the address on the same line.
I have now shared my solution with over 1350 folks and most report success. It is simple and free. Please let me know if it works for you too. You can contact me hutchipop@yahoo.com
Nov 01, 2007 | GE JRS04 Electric Single Oven
F7 error code
Hi Kathryn, I believe that I have already sent you my solution via another route. Hope you received it. Basicaly for anyone else with this problem, it is caused by a short circuit envolving the ribbon cable which connects the touchpanel to the electronic control. The solution varies slightly depending on whether you have a metal or plastic touch panel. If you have a plastic touch panel,you need to add some extra insulation between the two pieces of ribbon cable in the slot where it exits the touchpanel. You need to slip it down as far into the slot as it will go. A piece of paper, a piece of file card, a thin piece of mylar will all work just fine. If you have a metal touchpanel, you need to insulate the edges of the slot as well with paper or mylar. Insulate both edges. If you don't have two sections to the ribbon cable, obviously you can't put insulation between the sections. If you have a plastic touch panel and only one section to the ribbon, you are out of luck. There is nothing you can do except to purchase a new touch panel. Cleaning the contacts is a myth. It doesn't help. Hope this helps. Please let me know your results. Contact me at hutchipop@yahoo.com. Regards, Charlie
May 08, 2007 | GE Profile JT910SASS Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
1,388 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
