Eiki lc4300 projector
I just replace the exploded bulb and the "replacement bulb" warning lamp is still on; is there a reset? The new lamp does not appear to turn on
  • BFreden Aug 14, 2008
    Replaced bulb, new bulb works fine. But, the Please Replace the Lamp message remains on the screen. Is there a way to clear this message?
  • kuanileqa Jan 18, 2009
    I just replaced the exploded bulb for the Dell 1200mp and the projector will turn on and a light will emit from the new bulb for just a second or two and then it will shut off.  After another minute or so the "temp" light will come on and the unit will shut off.  Is it the bulb or the projector?
    Problem Solver:
  • 3 Answers
You need to go into the projector config screens and reset the lamp hours counter. Just did this myself. FYI my lamp life was 1352 hours and I have never used "bright mode". The new lamp is waaaaaay brighter than the one that just died so it was obviously ready to go. The crack of the bulb exploding made me jump! :)
Posted on Jan 03, 2010
  • 32 Answers
Check to make sure your lamp is completely in and connected properly, and the lamp door is closed completely, if still no light, pull the lamp out and make sure it is not broken from transporting it or handeling it.
Making sure you do not touch and glass portion of the lamp or surroundings. only touch plastic or "metal using clean dry paper towel for metal contact" as skin oil can destroy a lamp.
"If this dosen't help please reply for more help before marking a bad suggestion, thanks"
Posted on May 10, 2008
How do you reset your Eiki top panel without the remote?
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Sep 29, 2013 | Sanyo For Eiki Projector Lamp 6103400341...
How can you view the amount of bulb hours for an Eiki LC-986?
The manual for your projector is found here:
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_x986.pdf
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to
move a red frame pointer to SETTING Menu icon (refer to page 37).
Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
Mar 03, 2011 | Eiki LC X986 Multimedia Projector
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Bulb won't work
If you are sure that you installed the new bulb correctly , then I recommend that you reset your projector . Some projectors don't realize that you changed the bulb physically until you reset them .
please rate !
Apr 14, 2010 | Eiki LC X986 Multimedia Projector
Panasonic PT-60LCX64. What would happen if you
you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
How to check lamp hours on eiki lc - x50m
It does have a lamp timer but it is only accessible at start up if you hold down several buttons when you power the projector on. Eiki only supplies the info to dealers. I will see if I can post it later from my service notes.
Oct 19, 2009 | Eiki LC-X50M Projector
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Problems changing lamp
Try removing the new bulb and reinsert it and make sure it make a good connection. Be sure to follow your projector's instruction manual on how to change your bulb exactly.
May 19, 2007 | Eiki LC XNB3 Multimedia Projector
676 people viewed this question
jasbo
jasbo
