Question about Craftsman Saws
Craftsman circular saw. The blade wobbles on the shaft even though tightened down so the blade does not spin straight and steady. Without the blade I can wobble the shaft around with my fingers. Feels as if there is a bushing or something worn out along the shaft going back into the motor housing. Thoughts/suggestions? Repair or replace? thanks,
  • rjtomes Aug 30, 2010
    Thanks, been wanting to get a cordless, now's my chance!
  • 30 Answers
Depending on your budget, I suggest replacing the item. It sounds like your bearings are bad, which means tearing apart the case and replacing them (which don't cost much). There are two bearing encasements so you would need to replace both. If you're up for the challenge, give it a try! The bearings can typically be found on the manufacturers website.
Posted on Aug 30, 2010
I have 2 DW715 miter saws given to me, with the blades off one sounds wicked, you can spin it forward by hand but stops/locks up trying to spin in reverse. Sounds like a belt or bearing. The other one...
The first one sounds like an armature bearing - pretty easy fix if you have access to a press or even a bearing / gear puller. Make sure the saw is unplugged, remove the end cap on the motor and the 2 carbon brushes. remove the 4 screws holding the motor housing to the saw and pull it off. Then, pull the armature straight out - replace the bad bearing, and reverse process.
The second one sounds like it is missing the arbor bushing #152636-00 or it has a bad blade bolt #145344-01.
Nov 10, 2014 | Saws
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
The blade on my Mac Allister circular saw spins on the spindle when not powered. It appears the spindle nut doesn't tighten on to the blade enough. Should there be a washer either side of the blad
Yes, there must be a washer between the blade and the nut. On many saws this washer has a D-shaped hole to match a flat spot on the shaft. The back-side of this washer usually has a recess so that when the bolt or nut is tightened down it presses down on the saw blade, not the end of the shaft. Sometimes these washers are of the beveled spring type. Good luck!
Nov 06, 2012 | Saws
To remove the circular saw, which way do you turn the nut hold the blade on the saw?
For any saw blade or grinding wheel, the rule is this. Pushing against the points of the teeth should be the direction that tightens the nut. So you must loosen it in the same direction that the blade spins. For example, if your saw blade is on the right side of your saw, then the blade spins counterclockwise, and the wood pushes against blade clockwise - so you turn it counterclockwise to loosen it (which is in the same direction that the blade spins.). If the blade is on the left side of the saw, you loosen it clockwise. Good luck, Al K
May 22, 2011 | Sears Craftsman Circular Saw Blade
Cannot tighten blade on old craftsman circular saw.bolt turns blade shaft and motor without tighting blade
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Jan 24, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. ...
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Sep 16, 2010 | Craftsman Saws
Blade slips and doesn't turn, but the saw keeps going
Check the blade centre bolt for corrct tightness. If you have fitted a new blade, check to see if it is the type with a removable centre spacer (multi fit type) if it is, it sounds like the centre bolt has bee overtightened at some stage and deformed the spacer which now takes all the drive from the motor instead of the blade itself. Try giving the spacer a light file to remove any burrs. If all else fails, obtain a new blade which doesn't have the center spacer to avoid this problem
Apr 12, 2010 | Ryobi 7 1/4 In. Circular Saw W/ Dual...
Can't tighten the blade- it spins
Use a round shaft screwdriver place between the blade teeth to prevent it from turning.
Mar 04, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
Saws Logo
450 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
