Question about HP OfficeJet 6210 All-In-One InkJet Printer
My printer is jammed. Carriage does not move. Reset #3 does not work. Message on the LCD screen is: ERROR:0x07a74dd6 1959:lib_barracu Would be utmost grateful if someone can find a solution !!!
  • jimmy2chung Sep 03, 2010
    Hi Owoblow11
    I am afraid both options did not work.
    When I tried the first option i.e.
    -pull the cable at the back of the printer
    -press # and 6 keys while pushing cable back on
    a message appears " Semi full reset "
    -screen went blank but never came back on.
    When I turned on the printer, I get the same old message.
    The second option did not work either.
    Regards
    Jimmy
    Genius:
  • 1,478 Answers
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Posted on Sep 02, 2010
    Top Expert:
  • HP Master
  • 78,267 Answers
This price to fix this problem will exceed the cost of a new printer, they are less than $120 new, cost to repair is about $125
Posted on Sep 03, 2010
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Carriage Jam message that wont clear
ok..so please try these steps..
1)turn off the printer..open the front door of the printer(where you see the cartridge)..try moving the carriage manually from right to left or from left to right..if you are able to move then it is a false carriage jam error message..if you are unable to move then the machine should be replaced..because this is a hardware issue..
2)connect the printer to the wall outlet..and then check for the error message..if you are still getting the same error message..
3)unplug the power chord from the back of the printer..press and hold OK and CANCEL button together..
4)while pressing those two buttons plug in the power chord to the back of the printer..
5)after you plug in the power chord do not release those two buttons untill screen goes blank..
6)once the screen is blank release those two buttons and turn ON the printer..
check for the error message..if its still the same then go ahead and replace the machine..because it is false carriage jam error message..
please try these steps and let me know if the solution has worked..
Mar 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Carriage Jam Error display on the LCD!
open the lid ,you will see the cartridge track(steel bar) look both end of the track you will find something stuck over there most likely paper chip
Dec 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
My printer will not load and the window says the carriage is jammed. It is an HP Officejet 7410 All-in- one. It first had the message Paper jam and after I opened it and there was no paper jam I...
1. Check if there are broken parts inside the printer-carriage area
2. Turn the printer on and off
3. Clear any paper jam by opening the rear access door at the back of the printer. If there are no paper jams. Clean the rubber rollers with a lint free cloth that is moist with water
4. Make sure that the carriage can move freely
5. Remove then reinstall the ink cartridges
6. Make sure that the control-panel faceplate is correctly installed
7. Plug the printer directly to the wall outlet
8. Perform a partial reset on the printer.
a. Unplug the power cord from the All in One
b. Press and hold # and 3 while plugging the power cord
c. Do not release the two buttons unless the printer would say reset
9. Try to print
10. If this would not resolve your issue then the printer sensor is already defective.
Aug 06, 2008 | HP Office Equipment & Supplies
Carriage jam
Try this (it may not work) -
Perform a Semi-full Reset on the unit by following the steps below:
1. Make sure that the unit is on, and disconnect the power cord from the back of the unit.
2. On the unit keypad press the # and the 6 keys simultaneously and hold both keys down while plugging in the power cord.
3. The Semi-full Reset message will appear on the unit display.
Wait until the unit initialization process is complete. The unit will have recovered its original settings.
I've had this error before and had no obvious fault with the carriage (it moved freely and the encoder strip was in place) i managed to clear the error by stripping the printer down and cleaning around the service station area
May 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
