Question about Husqvarna Garden
Hi, I have Husqvarna chain saw model 357XP serial no 2006100483. The saw has suddenly refused to start and engine does not even fire. I was using it one day and on the next could not get it to start. I have done the folowing: a. checked spark and compression -- all good b. Fuel flow is good and mixture is correct strength c. Tried heating the plug and then re-inserting - no change. c. New plug fitted
  • workflow Aug 31, 2010
    Hi Mike, thank you for the response. All the items you suggest have already been double checked. To no avail. Any other ideas?
  • 905 Answers
Disassemble your chainsaw far enough that you can check the flywheel key. It may have partially sheared, throwing off the timing since you indicate that you have good spark, compression, and fuel flow. You might be suffering from a carburetor issue though. Check the key, then consult the user manual for diagram on how to clean the carb and go from there.
Posted on Aug 31, 2010
  • 1,498 Answers
Hi workflow,
Let me thank you for the excellent description of your problem, the symptoms and whats been done so far.
You have done everything I would have done so far.
If you have fuel, compression and spark, there is only one thing left, air.
  • Check the air filter for particulate matter and clean if needed
  • Check the choke linkage
  • Check the carb / trigger linkage
Withe the plug out, pull the cord a few times. The fuel air mix should come out as a fine mist.
How high is the compression? >80psi?
Have you tried starting ether?
Off the top of my head,
Posted on Aug 30, 2010
  • workflow Jul 14, 2011
    Found problem. The piston ring was glued into it's slot. Apparently due to too rich a mixture.
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I have a Husqvarna 357 xp which is about a year and a half old, but has had very little use for a professional saw. I was cutting with the saw upside down when it suddenly cut out. After letting it rest...
The carb is an "all position" type and shouldn't be the problem.
Check and clean/replace the fuel filter in the tank. Dirty or old gas, sawdust and/or water etc. settle on the bottom of the tank; and when the saw is turned over will plug the filter, causing the symptoms you discribe.
It is possible, if you used old gas(3 to 6 months) that small varnish particles have gotten through the fuel filter and have pluged the fine screen in the carb(located under the diaphram).
Sep 22, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Hi, I have a Husvarna 357XP chain saw. It wont start. Checked whole thing: Compression, bore , piston Carburetta Spark plus fitted new plug Mixture strength correct. Fule flow fine It was working...
take the plug out and warm it up inside your oven at 125 degrees for ten minutes. reinstall and try again
it works for me and tells me the electronic coils is starting to go bad
Aug 29, 2010 | Husqvarna Garden
I need to know how to adjust the bar oiler on my husqvarna chainsaw
A link to an OM for a 2005 Husqvarna 357XP/359 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
The procedure is on page 35.
CAUTION: It only has 3 positions; forcing it beyond the stops may render it inoperative.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
How can I tell what year my 357xp was built
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 24, 2010 | Husqvarna Chain Saw 20" Bar
Won't start back up
Do this and reply below with what you find. Please include the serial number (left side under top handle mount).
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. HTH
How we continue depends on how you reply. Remember I cannot see what you have done brevity here is not a good idea.
Lou
Feb 03, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 357xp flooding
2 things you might want to look at.
1) Vacuum test your fuel line. This is a common problem with huskys.
2) Check to see if the exhaust port or spark arrestor screen is plugged up. If so pick out a carbon deposits.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Engine cuts out
You probably have a fuel line that is cracked or has a hole in it of some sort. You should be able to take off the top cover and inspect these lines. If this is the problem, replace with new line & should work just fine. Let me know how it goes.
Mar 05, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
Chain locked
Can you turn the chainsaw over ( pull start cord s l o w l y .) if not your friend may have seized the engine. ( no oil in fuel, assuming it is two stroke.) then remove the chain and bar ( usually a couple of nuts/bolts) and try turning it over again. If it turns over or even starts, then the chain bar or clutch may need replacing. good luck.
Nov 02, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
199 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
