Question about Troy-Bilt Pony Garden Tiller
Reverse belt or transmission won't lock into place
  • 26 Answers
The reverse on the Pony tiller will not lock. You pull back on the reverse lever and as soon as you let go it will stop. This is normal operation for reverse.
Frank
Posted on Oct 07, 2010
Cub Cadet RT 65 rototiller wheels aren't engaging
It's possible you have snapped the shear pin in the transmission shaft.
Jan 25, 2018 | Cub Cadet Garden
My craftsman riding mower will not go into toward to reverse vise versa while motor is running
You didn't express whether,this tractor was a manual transmission or a transaxle type. If it's a transaxle type,then there is a shift handle on right side of the tractor. The position of the shift handle operates a module reverse switch assembly,in three positions(forward,reverse and neutral) This module has a safety switch located inside. This module is in a bad place.under the fender,where it can be subjected to water,dirt and vibration. Like most safety switches installed,they have a large failure rate. This maybe your problem. The module has only two screws holding it in place,you will have to remove it,to check the safety switch. The module and the switch are all in one,if the switch is bad you will have to purchase the module. This is just one answer that could be wrong with the tractor,not moving forward or reverse. The other,the prime mover belt is bad. This belt runs from the transaxle to the bottom of the motor's upper pulley. This belt stretches,over time and will cause the tractor not to move in any direction. If this is the case,there is no adjustment that can be made. Only a new belt will solve this. Remember the little handle,in the back of the tractor has't to be in (engaged) out (disengaged) the transaxle (transmission). When the handle is out,the transmission is disengaged,used when towing or pushing the tractor by hand. I know this answer,is rather long,but important to your question. Sincerely,Brad Locke 11/23/15
Aug 09, 2015 | Craftsman Garden
Cub cadet ltx1040 will not go forward or reverse
they smoke most likely because you have an idler pulley locked up or your transmission is locked up...
Nov 23, 2013 | Garden
On ocassion, my 1998 LaSabre (with 91,000 miles) won't back up when I shift into reverse. Transmission need replacing?
you need to have the transmission serviced and checked for broken gears. There is a chance its slipping and not locking into place when you shift because of a broken gear and this could cause more issues if not looked at soon. parts break and get jammed inside causing further damage. Take it to a reputable shop and have it checked soon.
Oct 28, 2011 | 1998 Buick LeSabre
I have a Craftsman DYS 4500 that the will not go forward or reverse. It cranks fine and the blades will engage but when you shift it in either forward or reverse nothing happens. It was working fine the...
did you have a back wheel off if so make sure the key way is in place it sits in the grove of the axle and the rim its about 1/4"x1/4" x 2" long if this is missing you will have no drive also if its a auto trans check your buypass lever hope this helps
Sep 06, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2004 vw passat wagon tdi Reverse slipping out of gear on automatic transmission while moving backwards several feet. After put into neutral and then back into reverse, same slipping out of gear...
Unfortunately this is not uncommon and I hate to tell people bad news but the problem is in the transmission. It sounds like the reverse is not locking in like it should. There is a pin inside the transmission that is supposed to lock it in place when you shift to reverse but that may have rounded off or seared off which would cause your problem. A clogged filter will also cause this issue. If you had that transmission back flushed, the normal method used today by shops that cost around $140 or so, then I can tell you for a fact that it needs to be rebuilt.
Jun 28, 2011 | 2004 Volkswagen Passat
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
Motor running will not go forward or reverse.
The transmission may be bad or the belt is slipping.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
Vechile will not shift into park or reverse
The first thing to check is the linkage. Sometimes the linkage will slip, Block the wheels on the car (both front and rear) to prevent rolling. Locate the shift linkage on your transmission, and loosen the nut. You should be able to move the shift lever through all the gears, including "P" and "R". Place the transmission shift lever in "Park" (on the transmission) then move the shift lever (inside the car) in the "P" position and tighten the nut (not a bad idea to use a new locking nut here) You should now be able to shift through all gears. If this does not work, you have a more serious problem that may include a worn or broken belt or broken parking pawl inside the transmission.
Apr 05, 2010 | 1994 Cadillac DeVille
17 hp rider mower 42 inch cut. willnot move in any gear or reverse. how does this transmission work?
it uses the belt as a clutch so that would be the first thing to check
Oct 18, 2009 | Garden
Troy-Bilt Pony Garden Tiller Logo
102 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
