Question about Bose Acoustimass 10 II System
How to open subwoofer on Acustimass 10 - Bose Acoustimass 10 II System
  • 158 Answers
On the bottom where the front panel and cabinet join there is a lever that must be slid sideways with a small flat head screwdriver
Posted on Aug 30, 2010
Acustimass 15 Subwoofer Not Working
Could be the amp is burned out? Maybe that is why they left it. Not worth the effort to move
Mar 29, 2014 | Onkyo TX-SV525 Receiver
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
I have a Bose lifestyle 25 from 1997 and I need a receiver power cord and a complete harness between the subwoofer and tha acustimass boxes. Do you know where I can find it ? Thank's
There's nothing special about the original power cord, so I'd go to Radio Shack or any electrical supply store and get it for $8.
http://www.radioshack.com/product/index.jsp?productId=3875429
Or you may have an unused one from other device lying around the house.
eBay has several of the unique connections you want.
Search "Bose lifestyle 25 cable".
Apr 10, 2011 | Bose Lifestyle 25 System
I have buy a amplifier of pioneer model vsx-rs319v-k. My question is that can I please the bose acustimass 6 series 111. please let me know by email : sabree_7111@yahoo.com
Bose speakers are specifically designed to be used in conjunction with the Bose Acustimas Power Module and won't work properly just as ordinary loudspeakers connected to the Pioneer amplifier
You could connect the Bose Acustimass module to the auxiliary output of the Pioneer or via the HDMI repeater. However, if you do this you will still need a set of loud speakers connected to the speaker outputs of the Pioneer.
Feb 25, 2011 | Pioneer Audio Players & Recorders
I have an old lanzar 10 inch subwoofer that is open airs series and need to know the required airspace for best performance
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Feb 11, 2011 | Lanzar MAX12D Car Subwoofer
I have a Phoenix Gold Octane Amp and 10d subwoofers. My friend took it out last week, and I want to put it back it, but I can't figure out where the power and ground wires go and where the speaker wire...
Ok, when you look at the amp, the power + and ground - will be on one side of the amp with another smaller opening in between them. That opening is for your remote wire from your radio. Without that, your amp will not receive the input voltage to signal it to turn on. The speakers will go into the remaining open holes. Your RCA wires will be on the opposite end of the amp.
Apr 29, 2010 | Phoenix Gold Octane-R 10/10d Car Subwoofer
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
Apr 19, 2010 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Dec 20, 2009 | Paradigm PDR 10 Speaker
I have a fusion 10'' sub with amp built in and i have it all wired and everything. I got power from the battery to the amp my groung is good all my fuses are good and still no subwoofer playing is my amp...
open it up if you can and check internal connections to the sub, if all looks good, open up the amp and check the internal fuse. becareful of voltage hazards
Aug 15, 2009 | Car Audio & Video
I have a acustimass 9 system , but i dont kno whow to plug it
The plug design they use is proprietary. So you would have to cut off the plug and connect your own jack to the wiring to be able to use it elsewhere.
Jun 18, 2009 | Bose Cinemate Digital Home Theater System...
Bose Acoustimass 10 II System Logo
223 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
