Question about Gateway (6500345) 200-Watt Power Supply
Is it necessary to clean the fan on it? - Gateway (6500345) 200-Watt Power Supply
  • Gateway Master
  • 11,800 Answers
Yes, but it's not necessary to remove its cover, just blow some air thru it.
Posted on Aug 30, 2010
How to clean the metal fan in the back
It is only necessary to keep the dust off the blades and the fins that the fan blows on. It is not necessary to make then shiny brite. Simply vacuum the blades and the fins.
Dec 06, 2016 | Refrigerators
Cpu temp gets fatal
Open the case and clean the fans and the "ductwork" thoroughly. If necessary, replace the fan.
Apr 10, 2014 | ASUS N50VN-1A fan - N50VN-1A laptop cpu...
Eco 180dvp What is an error code 5? Thanks
Imperfect Combustion
Clean air inlet filter.
Clean combustion air fan.
Clean heat exchanger fins.
Check for adequate combustion air ventilation openings and clean if necessary.
Check vent system for partial blockage and correct as necessary.
Nov 02, 2013 | Rheem Paloma Tankless Water Heaters...
What is error 28
Precor Error 28, Temperature Too High Probable Cause 1. The lower PCA cooling fan is clogged.
2. The lower PCA cooling fan is inoperative.
3. The running belt and/or deck are badly worn.
4. The lower PCA is bad.
5. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Inspect the fan mounted on the lower PCA for dust/debris buildup. Clean if necessary, ensuring the fan spins freely. Some lower PCA's do not have a cooling fan and others may have the fan mounted on the underside of the lower PCA making it not as visible.
  2. The fan was free of dust or debris but does not spin. Make sure that the fan wiring is secure and properly connected to the lower PCA. If no obstruction to the fan and the wiring is good but fan still doesn't turn, replace the lower PCA.
  3. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions; compare the values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  5. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 28
Sep 13, 2013 | Precor C966i Treadmill C 966i
Clean fan
get a can of air from walmart or whoever and blow the vents out with short bursts . it's easy and necessary to blow it out every so often.. looks like this on ebay Compressed Air Gas Aerosol Can Duster Cleaner
Feb 01, 2012 | Toshiba Satellite Pro L300 Notebook
The cooled air is coming out at a very weak rate. The ac unit outside is blowing out cool air when the neighbor's is blowing out warm air. The house is just not getting cool. AC has been on for 4 days...
Turn off your A/C and put your fan switch in ON or FAN. Run the fan only for approx 3 hours. Check your air filter and clean/replace as necessary. Also check your evaporator coil and clean if necessary. It is possible that your evaporator coil is frozen up from a dirty filter or coil. If it continues to be a problem, you probably have a refrigerant problem which will require a certified service technician to address. Try taking care of the filter and coil first. :-)
May 28, 2010 | Honeywell Electronic Programmable...
Is it necessary to clean refrigerator coils? If
just the outside coils and fan motor coils vacume them with unit unplugged
Mar 29, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
My Rtg-74pvp water heater shuts off. I retrieved the error code: 1E/05. What do I do next?
05 Imperfect Combustion Alarm
If this does not help; contact Rheem customer support.
Nov 11, 2009 | Rheem Tankless Hot Water Heater...
Case coling fan is very loud
Hey there Ohio,
There are a few things that cause a normally silent fan to get noisy.
  • Dust building up - Unlikely, but check. Clean if necessary.
  • Some internal wiring brushing against the trailing edge of the fan blades - Likely only if the case was recently opened. Re-open and check, relocate the wiring if necessary.
  • The fan is getting ready to fail - Most likely. Replace the fan. If you have an unused computer, pull a fan out of that one to use. New fans are available for under $20.00 USD .
This replacement is very easy.
  1. Four screws out
  2. Unplug
  3. Remove old fan, put new one in.
  4. Plug in
  5. Four screws in
Don't wait until it fails, though. A cool computer is a happy computer.
Hope this helps,
Mike
Nov 28, 2008 | Computers & Internet
Gateway (6500345) 200-Watt Power Supply Logo
19 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
