Question about HP Officejet 5610 All-In-One InkJet Printer
Scanning to WP 9
Intermittently, scanner will act as if its working, all scanning processes proceed, then it opens to WP 9 with a blank screen. Occasionally, the scan takes. Have tried the reinstall, etc.
    Scholar:
  • 107 Answers
Hi this should be problem with Software u need to Install "HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch" for Scan Quality
please use below link for patch .select correct OS & download "HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch"
if this information is useful for u please Rate me......
Posted on Jun 16, 2008
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
If it is your first time using your printer, then you need to install the driver for it to work.
If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:
1. Connection error
2. Driver problem
First thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly.
If rebooting your computer and printer won't fix the problem. Here are the things that you can do.
1. Connection error:
a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b.
b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process.
If all steps above don't work, then you need to check the driver.
Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work.
If it doesn't, please reply to this thread.
Thank you for using fixya.com
Carlo Adrian
Nov 14, 2012 | Dell Photo 926 All-in-One Printer
Hp 2210xi printer will print from computer, but not print a copy placed on the glass. machine acts like it's printing, but page comes out blank and no error message.
Try restating your computer, uninstall the printer software, restart your computer, install printer software again, and restart computer again. (leave the printer off during this process unless told otherwise by the on-screen instructions).
If the above doesn't work, then it could be a hardware issue with the scanner. Try scanning a document to your computer and see if that works. If it doesn't, then your device probably needs a hardware repair...hopefully something is just loose in there.
Hope that helps!
Mar 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
Scanning Blank
Try and re-install the scanner, check the settings of the scanner software you are using and change the settings to scan picture or scan in colour. Thanks
May 13, 2010 | IRIScan Executive 2 Flatbed Scanner
The scanner warms up and goes through its process but does not transfer picture to screen - comes through a blank white page and then the screen turns black reinstalled the driver and rebooted the computer...
Most of the scanner software has options to set the scan area. Yours MAY have got set to a tiny area outside the thing you are scanning. So check the options including the scanning resolution. Reinstalling the I/O driver is useless. Re-installing the scanning software itself MIGHT restore the resolution to defaults. If there is a way to restore defaults, try that.
SOMETIMES re-installing software remembers your old settings, which could be the problem to start with.
Mar 26, 2010 | HP ScanJet 2100C Flatbed Scanner
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Keep scandall in background
Possibly you need a more professional program. Scanning utilities following scanners (free) aren't a "Production" tool. Using PixEdit you can scan with one single click and after the scan is finished you could scan the next stack of pages. While it is then scanning the previosus document is processed with blank page removal, deskew, OCR, barcode recognition and a lot of other stuff. The reason is PixEdit using the mulitple cores in modern PCs.
Sep 17, 2008 | Fujitsu fi-5120C
Slow scanning
I had the same problem on a Mac after upgrading OSX (on 10.5.7 now).
Downloaded the newest scanner driver from Canon:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=13800
and now it scans without delay!
I always scan using MP Navigator, not from the scanner itself: let's me edit the scans and save where I want as .jpg or .pdf.
May 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Scanner won't scan
try connecting it to another computer. If it works, then it is a prblem with your computer, otherwise it is with your scanner hardware.
If you can open the scanner clean the circuit board with (Isopropyl alcohol) IPA solution. you can also try replacing the ribbon type cables connecting the print head.
If the problem arised due to dust accumulation, the above action should solve the problem.
Jan 14, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
