My printer wont print keeps saiying port in use please wait
  • martymarg Jul 18, 2008
    Have the same problem. First print job prints OK. Try to print a second job and get "Port in use - please wait". Nothing happens. Restart the computer and the doc will print.
    Have un installed and re installed, but same issue.
  • yarild83 Aug 07, 2008
    I'm having the same problem. I've uninstalled, reinstalled, and have downloaded updated drivers and nothing has worked.
  • 54 Answers
Try to reinstall the drivers and check again
Posted on May 08, 2008
Error0xc18a001 i cant print because of this message what do i need to do ? please help
ello thanks for using Fixya
To solve the error code
0xc18a001. There is following solution.
Follow it step by step
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
By this error will automatically remove. But if u face still this error then printer service required
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error code 0xc19a0021
Hello thanks for using fixya
To solve the error code 0xc19a0021. There is following solution.
Please keep thumbs up in do Rating if it is helpful
Jan 07, 2011 | HP Photosmart C5180 All-In-One InkJet...
Printer wont scan
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | Lexmark X2500 All-In-One Printer
PRINTER W0NT PRINT FROM COMPUTER.
If your printer is using a USB cable to connect to the computer, please try the instuctions below:
1. Go to the Control Panel > Printers
2. Right-click the printer icon > Properties
3. Ports tab > select USB001 > click on Apply so that the printer name would appear right next to the port.
4. If USB001 is already selected, try to select another USB Virtual Printer Port.
5. Save the configuration
6. Make sure to set the printer to online.
7. Try printing a test page
Apr 08, 2009 | Laptop Parts & Accessories
I just put new ink Cartridges but still wont print
Most of the time the "problem communicating with the printer" message pops up on Lexmark X1185 series when the driver gets corrupted. The best fix for this issue would be to uninstall the software first. Try connecting the USB to a different USB port (Please avoid using USB hubs, if any) and then reinstall the software. This should normally fix the printer communication issues!
Good Luck
Dec 12, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Printer wont print what I want only mixed up words on top of page
With the printer on, pull the power plug out of the wall socket. Then power off your PC.
Wait a minute, then plug the printer power cord back into the wall. Turn the printer on, wait a minute, then power up your PC. It should print normally again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 08, 2008 | HP DeskJet 5550 InkJet Printer
My Lexmark x4550 all-in-one printer wont print anymore.It worked for a short time but now it doesnt print.I keep getting the error message communication problem,the printer cannot communicate with the...
You need to reconfigure the port. Go to the printer icon in "Control Panel" and open "Printers."
You will see that your printer is "Offline."
Rt Click on the printer and select "Properties." Click on the "Ports" Tab, highlight your printer by clicking on it and then select "Configure Port." This will open a new window where you then click on "Configure." In the next window choose DHCP (Radio Button) and wait until finished.
Remember back where you first started, Rt click your printer again and choose "Use Printer online." When the process is finished close all windows and you will be printing.
This also works with many of the Dell Photo printers as they are made by Lexmark. Unfortunately you may find that if you turn your computer off it may go "offline" again and you will have to do this process all over again. Good Luck.
Jun 10, 2008 | Computers & Internet
67 people viewed this question
