Question about NetGear DG834G Wireless Router
Set security on wireless router - NetGear DG834G Wireless Router
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
* Open a Web browser * type http://192.168.0.1 * Select Wireless settings on the Left hand side * Select a security type WEP or WPA-PSK * Make your own security key and save the settings
Posted on Sep 02, 2010
5 Suggested Answers
SOURCE: Another problem... wireless router Allied Telesyn wa1104g
I have intalled hundreds of linksys routers, so when I heard such a problem described above, I though it would be just a system error due to the OS messed up. but with the new router WRT160N, I actually had that problem. they raised security level (especially for WEP), but the router doesn't have options for it in configuration. so, we will have to set our computers manually to make work with it.
Do manual setup by typing SSID, Security mode, Key.... and make sure to disable 802.11x security.
Posted on Apr 16, 2009
SOURCE: my D-Link router periodically resets the security
When you made your changes did you save them before exiting? Also the reset button has a very small hole and a pen will probably not reach the button. Use a straightened paper clip or toothpick, the button is easy to push in.
Waynebob.
Posted on Dec 15, 2009
  • 72 Answers
SOURCE: does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
Posted on Jan 05, 2010
SOURCE: Edimax BR-6424n router wireless works fine with
When you enter a WEP key, you must completely redo the new connection on the PC, remove the adapter and start all over again as in reinstall the driver, then do the connect to network, thing. BTW, you MUST save the setting in the router, and reboot the router, and then reboot PC, and then try to establish a connection. You should also use this tip, when you generate that BIG number WAP?WEP Key, copy/paste it to a notepad document, and save as wapkey. No after saving it in router and rebooting, when you come to the Field to enter the WAP/WEP key when logging onto the Router, you can simply copy & paste back from that notepad document you saved before. Now you should be able to login, remember to save network setting too. so you don't have to enter it each time you login.
Posted on Jun 25, 2010
The wireless network security settings on laptop do not match settings on router?
Hello.
- This error occurs when the wireless security that you set on the wireless laptop does not match the wireless security on the router.
  • If the wireless router's security setting is WPA but on the laptop you used WEP for the wireless security, that's when a mismatch occurs.
- What you can do to resolve the problem is to delete the wireless profile you created on the laptop. After that, let the laptop search for wireless connection available, select the correct wireless settings and it should connect.
--For example the operating system of your computer is Vista, in order to remove the wireless profile you created and reconnect to the wireless router, do the following instructions:- Go to Start>Control Panel>Network and Internet> Network and Sharing Center- Click on Manage Wireless Networks on the left panel. Delete the wireless profile then Search for available wireless networks again. Type the correct wireless security settings on your laptop
-- If you would like to know what wireless security has been setup on the router, connect the laptop or use a desktop which is wired to the router then access the router setup page by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter. Enter admin for the router user name and your password (or the default, password).
--After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the wireless security or you can setup wireless security from there if you haven't done so.
Hope this helps. Have a nice day. Don't forget to vote if you find this guide helpful. Thanks.
Nov 26, 2011 | NetGear WNR2000 Wireless Router
Where is the network security key
goto settings security ,now here enter the WEP key.
Feb 12, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G WRT54G Router
How do I secure my Dynamode BR 6004 WG1 Iam a
To secure your wireless network from unauthorized access, you need to at least configure the wireless router with encryption, and the SSID, and change the router's default login password.
Please follow these instructions :-
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Jul 23, 2010 | Dynamode (R-ADSL-C4-W) Wireless Router
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
Jun 18, 2010 | Linksys WRT160N Wireless Router
Says not secure
Dec 06, 2009 | Belkin (F5D9230-4) Wireless Router...
HOW DO i PUT A PASSWORD IN A ROUTER RG60SE?
Not only should you change the default password but you need to secure your wireless router.
Nov 21, 2009 | MSI Computers & Internet
Wireless security
Just open the link below for the step by step procedure in setting wireless security on your router.
Setting up wireless security on a Belkin F5D7230 Wireless Router:
Dec 22, 2008 | Belkin (F5D7230-4) Router (587009)
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NetGear DG834G Wireless Router Logo
55 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
