Question about LG Televison & Video
LG42 5010 LCD TV developed a fault where right hand half of screen is dark with blurred colours for about 5 mins then corrects itself. Local engineer says it is the display but it is only 21 months old. Got TV back from them and after fault goes away display looks fine aort from occasional jitter every 10 secs or so. Could it be a fault other than the display? Brian Kerr
  • brian_kerr Aug 30, 2010
    Thanks taran_2005 for you comments which are at least hopeful. When the set is first switched on the right hand side is dark with blurry colours and a long persistance of the previous image. Then after about 5 minutes the screen instantly changes at the RHS to a perfect image even on full HD. Since the TV was taken in for an estimate and its return I now notice a jitter every 10secs or so but on the whole the picture is perfect. The repair compnay said it was the display and would cost £400 to replace and os is not a viable repair. Brian
    taran_2005, why would the display operate almost normally after 5 mins if it is faulty. Are the T con boards expensive?
    Brian
  • 10,515 Answers
There could be 2 reasons for the same i.e Bad LCD panel ( which is quite common ) or T Con board for the same. It would be tough to distinguish between the two without looking at the TV.However, i could provide you with an idea that most of us would take into consideration.
If you look at the TV, if the image is not perfectly linear, then most probably it is T Con board.However, If the bad side slowly blends into the good side, it is probably bad LCD Panel.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 30, 2010
  • taran_2005
    taran_2005 Aug 30, 2010
    Thanks for your response!!
    I have not checked the price for T conn board for this model.However, for most of the TV's - it is anywhere between $75 - $100. If you call any tech to replace it , including the labor cost - it would be around $200 - $250.
    My thumb rule is - If the cost of the repair is more than half the price of the original value - time for the new one. So, does it wise to spend $250 for repair for a TV worth $450???
    Again - Cost of repair depends on many factors like location, technician, whether it is a small shop or big repair center and so on.
    You could get a used TV ( same model ) for around $200. That's a different story, if you purchase a non working TV ( same model ) from craiglist for $25 or so and the pull out T conn board and swap to see if that works. Other than this, either way you would be at loss. It is better to bite the bullet and buy a new one. ( again that's my personal opinion ).
    Any fault in T conn board would cause TV screen to cause such effects. I have seen even more funny things that could happen. Few models have T conn board as a part of LCD display. I have no idea regarding this LG Model. If that's the case, the complete LCD assembly has to be changed.
    Hope i helped you.
SAmsung Series 5 LA40B530P7RXXa Version A401 Blurred colour on TV
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 16, 2016 | Samsung Cameras
Very blurry picture / vertical colour lines
It sounds that the LVDS cable; the cable that connects to T'Con board to LCD panel is loosely fitted. Check it first. If it is found OK, the panel itself should be suspected. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Faulty screenshots of LCD TV screens, have been illustrated. Compare them to your TVs present screen view, and be sure. Check the site with patience.
Jun 25, 2013 | Sharp LC Televison & Video
Dark screen on samsung lnt4669fx lcd tv, what could be the problem?
As you suspect, it might be of T'Con board fault. Check all the flat cables connected to T'Con to panel should be checked first for any loose contacts. Re-seat them once. If you wish to know more, check this site. It has illustrations of screen shots, for Samsung LCD TVs, with a faulty T'Con board. Can compare these images with your TVs.
Jan 24, 2013 | Samsung LNT4669 TV
SCREEN BLACK ON ONE SIDE
Sorry long delay on seeing this - I forgot I had a Fixya account! Unfortunately this is the symptom of a dead or dying Inverter - LCD screens have two sets of Inverters - left and right. Both are high voltage (i.e. usually far higher than the input voltage) and are used to turn on the back-lighting in LCD displays. the lights themselves are much light Fluorescant tubes - which is why a White screen is so White. What you are experiencing is that the Right side inverter is pretty much end of life - it could be a general fault with the unit in manufacture or just a fault that has developed. It could also be the mainboard itself not supplying the correct signal to the inverter circuitry to turn it on. It could indeed also be the backlight itself.
Jan 05, 2013 | Vizio VW46LFHDTV10A 46 in. LCD TV
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
THe entire right half of our Vizio 46in vw46L TV has gone dark and has a motion blur problem as well. The darkness started across the top third of the screen but for the last few days it has been just the...
I am having a similar problem. Try reseating the ribbon cables being very careful with the clips that hold them. On the T-Con board. Sounds like either the Lcd panel screen itself or the t-con board.
Oct 31, 2010 | Vizio VW46LFHDTV10A 46 in. LCD TV
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
LCD TV has dark smears on picture
This not repairable,it a LCD screen have minor pixels cracks in the LCD screen itself,some body hit the LCD Screen with somethings.
Jan 12, 2010 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
My Hitachi model 26L6200 develops a fault after about 40 mins to an hour with a shimmering vertical band 8 inches wide at the right hand side. This band eventually becomes a wall of coloured...
NOT really a solution; I deduced there is an overheating problem likely with a faulty component, so I looked at Thompson Directory and found local repair engineer who has the TV now.
I really wondered if this was a known common problem.
Thanks for you interest.
RHT
Jul 21, 2008 | Hitachi Televison & Video
Televison & Video Logo
209 people viewed this question
Computer Repairing
Computer Repairing
