Question about Intex Challenger 3 Boat Kit
I don't know how to inflate step 3 on an intex challenger 3 boat
2 Suggested Answers
DD1992
  • 122 Answers
SOURCE: how do deflate my raft challenger 3 also is there a site that
stick a straw were you put air into it
Posted on Aug 23, 2009
Lost air stopper
Nothing helps. Get a polypro kayak that doesn't need inflation!!!!
Mar 29, 2014 | Challenger Intex K1 1 Person Inflatable...
Intex Challenger K1 Rudder
No rudder system is available for INFLATABLE kayaks. They are no good for oceans or lakes only a swimming pool. Get a good solid Ocean Kayak or other brand that is RIGID. Your life may depend on it.
Jul 24, 2013 | Challenger Intex K1 1 Person Inflatable...
Intex k1 Challenger replacement skeg
Found some on ebay under "Skeg, Keel, Fin Replacement Intex Challenger". They sell them every few weeks & the sell out quickly. They are actually an improved design & they sell at about $15.00
Jul 01, 2013 | Challenger Intex K1 1 Person Inflatable...
Intex challenger 400 parts
Contact Inflatable boat specialist. There is one that I know of in ventura california. Contact them first and go from there. 3695 East Harbor Boulevard Ventura, CA 93001
(805) 644-6290
Aug 28, 2012 | Intex Challenger 400 Inflatable Boat 4 Man...
HELP! My new little 200 boat will NOT INFLATE! Have tried everything. I had another one that inflated immediately and this one will not! it is as if it has no way in the valves for the air to get into...
Hi, perhaps the problem may lie with the inflating method. Have you checked to see if the pump is actually giving air? These rafts usually have multiple bladders, are they all giving you this problem? Also, there is a plastic flap at the inside the base of the valve to prevent too much air from escaping before you plug it. you mush insert the air chuck adapter past this point. Good Luck!
Nov 10, 2010 | Intex Excursion 4 Inflatable Boat Set
Best way to locate and repair a slow leak in a intex seahawk 500 inflatable
Get some bubble bath, mr. bubble, or just dish soap, thinned out with water, spray it all over the boat, you will get it cleaned up and find the leak at the same time. When you see th e stream of bubbles coming out, mark it, get it dried off and patch it up. I think they use a contac cement on the Hypolon boats, or is it neoprene? Do you have a patch kit? Any pieces of material for a patch? The hardware store has pvc rubber used for shower pans, that might stick on there, clean it good with laq thinner, and brush on some glue, both pieces, let dry, then slap them together. You will know if it will work. Or else look up the manufacturers recommendations. he boat supply might have patch kits in stock. Hope this helps.
Jun 24, 2010 | Intex Excursion 4 Inflatable Boat Set
Punctured air bedsmall puncture and have guest staying and need to repair it
Best thing I have found that works good is a patch for a bicycle tire. They have other small patches that are very similar, I just find the bicycle patches more convenient and usually cheaper. Hope this helps.
Jan 02, 2010 | Intex Challenger 3 Boat Kit
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
I am looking at a cabin cruiser with the view to buying same. Have been told that it is a cut down version of a Challenger yacht (40) Is their such an animal? Don
It may be that the seller is referring to the Challenger 40 sailboat, which came with either a marconi or ketch sail rig. Compare the deck layout, photos at the bottom of page, and the specifications with the boat on:
http://www.sailboatlistings.com/cgi-bin/saildata/db.cgi?db=default&uid=default&view_records=1&ID=14024&mh=1
...then it is the same or similar, this may be the boat referred to by the seller. There are also go-fast power boats with the name Challenger, but not something that a re-make would produce a nice cabin cruiser from.
Jul 20, 2009 | Intex Challenger 3 Boat Kit
Intex Challenger 3 Boat Kit Logo
42 people viewed this question
Top Intex Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Intex Boating Expert? Answer questions, earn points and help others
