Question about Frigidaire Microwave Ovens
Error code F-14 when using the oven on model PFEF374ES FRIGIDAIRE STOVE
  • 3,083 Answers
Read the following blog, it describes Frigidaire's F14 error code:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/47659-frigidaire-stove-displaying-f14-error.html
Although your model differs from the one in this blog, the error code will be the same as far as symptoms go, and should clue you in as to what to check, clean, etc.
Also, here is a pdf that describes this fault, also:
manuals.frigidaire.com/prodinfo_pdf/Springfield/316904402.pdf
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 30, 2010
Electric frigidaire stove model:RE-38S serial :61CD4495 oven wont heat. checked;continuity,cord,wiring and outlet all was good. how do i fix this problem?
can not say as do not know if it is a conventional stove oven or a microwave oven . I would call a local repair service
Sep 13, 2017 | Frigidaire Microwave Ovens
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
How to work oven. just got stove from freind
First thing I would do is talk to the friend ... you don't mention the model #, BTW. Don't expect much of an answer based on your question. Frigidaire probably has made millions of ovens in thousands of models for sale hundreds of markets.
Thank you for your interest in FixYa.com
Sep 18, 2011 | Frigidaire Microwave Ovens
Manual for Frigidaire 95CC-2689 stove top oven
Frigidaire has a page dedicated to getting you in touch with a manual
http://www.frigidaire.com/manuals
but check to plate on your microwave to make sure you have the right model number or you will get a null answer
Dec 03, 2010 | Microwave Ovens
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
MY FIGIDAIRE GALLERY SERIES MICROWAVE IS LEAKING BLACK OIL
hi my name is mark, if nothing boiled over in the microwave. the oil could be coming from a capacitor in the microwave oven. i would call for service before it fails.
Mar 16, 2009 | Frigidaire GLMV169D Microwave Oven
Microwave Ovens Logo
600 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
