Question about E-Machines eMachines Desktop PC
Power problem I have an e machines desktop computer. When I press the circular button on the front of the tower, nothing happens. It is like the power is dead. I tried switching out the power cord, but that did not solve the problem.
  • 558 Answers
Look for a switch on the back of the computer by the power supply it must be in the I position not the O . if that will not work then the motherboard my be damaged or the power supply itself not the cord for it is very rare for a power cord to polarize any more. last the power button itself may be damaged but in al my years I have not found a bad power button yet. Always it has been the motherboard or the power supply.
Posted on May 08, 2008
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
Press tower button and nothing happens
press power button and nathing happens, u need to check your power supply
Nov 27, 2011 | E-Machines eMachines Desktop PC
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
Veriton 7200D ACER - I went to turn on my computer today and it wont turn on. On the front of the tower there is a green light flashing intermittently. Looking at the back of the machine I see that the...
Press and HOLD the ON/OFF button for TEN seconds, until the computer turns itself off.
Then, press the ON/OFF button as per normal, and it should start.
Sep 27, 2010 | Acer Veriton 7200D PC Desktop
On start up i have lights 1 and 3 lit up only and a periodic buzzing noise from inside the tower (every couple of seconds). after about 15 seconds the buzzing stops, the lights stay on and nothing else...
The problem is due loose memory sticks or mismatched memory sticks.
You need to open the computer tower and reseat the memory modules on the machine to fix the issue.
How to do it ? follow the link below
Thanks for using fixya
May 19, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
I have a desktop E Machine. When i push in the
This sounds like a power supply went bad. Did you either have a power surge or did someone shut down the computer by pulling out the plug?
Feb 19, 2009 | E-Machines eMachines Desktop PC
Power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Jan 10, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
