Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Robo-kleen only moves back every 2 feet. - Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
  • 640 Answers
You need to check your impeller and your axle bearings. To check the pool cleaners impeller, make sure that the transformer is unplugged to prevent electrical shock. Take the top grill off by removing the 2 screws from the top. Remove any debris that you find and replace the grill. Secondly, check all of the axles and the wheels for debris, hair, or lint that would restrict movement. Make sure that you do not force the wheels. If you aren't able to fix it with these solutions, it could be your gear box or another electronic section of the cleaner. You will need to have it services professionally.
Posted on May 26, 2011
I have not used my Robo Kleen for several years. It was in storage in the basement. I put it in the pool and at first only moved a couple of inches. I manually rotated the wheels and they are very...
try keep working the wheels, it might free up. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 11, 2013 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen plus not working
if water pump ok pushing water check drive motor if wheels don't move
May 18, 2013 | Smartpool Robo Kleen
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen pool cleaned keeps flipping upside down. happens every time, i will watch it for a few minutes then come back later to check on it and it is upside down in the pool
check to see if the fan on top moves
if its stuck , then the motor is not pumping constant
and the pump may need some kind of lube
graphite perhaps
Sep 03, 2011 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen is brand new and from day one, it just rocks back and forth. It moves forward about 1 foot and then back about 1 foot.
Sounds like water in the motor . had the same problem and after drying out it worked for a week then the same problem
Aug 05, 2011 | Smartpool Dolphin Robo - Kleen Above...
When I place my Robo-Kleen in the pool, it now only travels about two feet, rocking back and forth. Occasionally, it will go a few additional feet, but then stops. I also don't seem to be getting the...
I would first check for obstructions in the front and back wheel axles. Then, take the top grill off and make sure that the impeller is not jammed. It sounds more likely to me that you are having a problem with the pool cleaners gear box or drive system. If it is still under warranty, send it back to the manufacturer. If its not, you will need to have it repaired by an experienced pool repair person.
Jul 20, 2011 | Smartpool Dolphin Robo - Kleen Above...
Robo-kleen just moves back and forth in about a 2 foot section - why?
There could be several problems with this pool cleaner that cause it to move back and forth. First, check the impeller to make sure that its not jammed. Take the top grill off by removing the 2 screws from the top. Remove the debris. Replace the top grill and tighten the 2 screws. Next, check your front and rear wheels for any obstruction that could cause lack of movement. You might also need to remove the limit screw from the wheels for greater movement abilities.
Apr 15, 2011 | Smartpool Dolphin Robo - Kleen Above...
ROBOT GOES BACK AND FORTH 2 FEET ONLY
There are several things to check for with these pool cleaners. First, make sure that there are not kinks or knots in the cable that would restrict movement. Make sure that there is not hair, fabric, or other debris in the impeller. This can also cause the back and forth movement. Check for debris or leaves caught in the axle bearings.
Aug 02, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
127 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
