Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Osd menu popping up ..how do I stop it - HP Pavilion F1503 15" LCD Flat Panel Monitor
    Guru:
  • 377 Answers
Just to make sure we are talking about the same thing, when talking about the OSD (on-screen display) that normally refers to the monitor only, such as the menu to adjust horizontal positioning, or the mode (digital or analog) setting. Is that what you are talking about? If so, what does it say?<br /> <br /> Did this just start? Have you recently changed resolution settings? I note in your manual the following warning:<br /> <blockquote><font color="Navy">The On Screen Display manager also features pop-up<br /> warning messages for certain situations, such as if you<br /> attempt to set the monitor resolution outside the<br /> recommended range.</font></blockquote>It also says:<blockquote>Your monitor is optimized for 1024 X 768 @ 60 Hz. </blockquote>Are all cable connections secure?<br /><br />And if you right click on the Desktop &gt; Properties &gt; Settings, what is the resolution set to? 1024x768 it will be ok<br />
Posted on Aug 30, 2010
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
mvincentc
May 11, 2011 | Hannspree HW191D LCD Monitor
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Osd lockout
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
I hope it helps.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
Hello how do i get rid of all the viruses in my computer and how do i stop the osd lockout from popping up on my computer
You can install and run a combination of anti virus and anti spyware software
http://www.avg.com/us-en/download-trial
Install and run the same.
Press the menu button on the screen, you would default go to OSD menu, move the OSD lock to off mode
Thanks for using Fixya
Proton
Nov 12, 2009 | HP W2207H 22 Notebook
I have a compaq w17q monitor and the osd locked message keeps popping up. how do I get this to stop?
Hold the menu button in WHILE turning on the power. This toggles the state of teh OSD lock.
Nov 04, 2009 | Philips 150S4FB 15" LCD Monitor
Osd menu keeps popping up
It is the malfunction of the monitor button or circuit pannel responsible for OSD. Get it repaired/replaced.
Regards,
Shrey
Oct 02, 2009 | HP Pavilion F1523 15" LCD Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Mar 28, 2009 | Philips 170S7FS 17" LCD Monitor
Contrast pop up
Is the OSD button stuck on the front of the monitor? Can you control the OSD menu with software or firmware? It may be the button interface/hardware.
Jan 03, 2009 | Computers & Internet
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
