Question about Kitchen Ranges
The frig trips its circuit breaker in the fuse box. Obviously no cooling and no lights. Pluging it in a different outlet "blows" that circuit breaker immediately. Frig is 6 years old and previously repaired.
  • Kitchen Ranges Master
  • 43,501 Answers
There is a bad wire...(dead short) or a bad compressor... you will need to check things out to figure out what the actual problem is it could be many...
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
A circuit was out,which included tv and frig, moved frig everything went back on! what happened?
If the whole house power wasn't down, then you could have a circuit breaker that is flaky or a wire connection in the breaker panel or at one of the outlet boxes along the way from the panel to your outlets. If it happened once, it will happen again. I'd cycle the power at the breaker, just on general principles to make sure the movable components within the breaker are where they are supposed to be. If it happens again, I'd start at the breaker and check every outlet box in that circuit for a loose connection, either a screw or wirenut. Breakers aren't expensive to replace if you can't find any loose connections along the way.
Apr 15, 2014 | Samsung Refrigerators
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Light downstair keep tripping our fuse box
Is it really a fuse box ? or breakers ? If nothing is running on that circuit ,you probably have a short circuit , the fuse or breaker is saving you from a fire.
Apr 30, 2012 | Cars & Trucks
We moved our magic chef frig on the deck-plugged it into an outlet with too many thing running. The breaker tripped.Not the frig light comes on but the frig does not work. Is there a reset button? If so,...
There is no reset button.
Firstly turn the fridge off at the wall switch. Wait 5 minutes then switch the power back on. If the fridge still does not start then you have a problem with either the fridge electrical circuit has a fault or the circuit board fuse has blown.
Apr 01, 2011 | Magic Chef CTB1722 Top Freezer...
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
I opened my fridge to get something out, shut the door and EVERYTHING WENT OUT??? No lights, no nothing??? I tripped the breaker and checked the cord etc... Nothing????
Make sure your getting power at the outlet by pluging in somthing like a hair dryer. If your getting power at your outlet then you probably have a controlboard problem.
If you don't have power then first look for GFI RESET in the kitchen. or fuse box.
Aug 11, 2010 | LG LFC21760 Bottom Freezer French Door...
1700 watt fog machine keep tripping GFC and blowing fog machine fuse
the fog machine needs to be on a dedicated line because of the wattage it does and the amp is rated as a 15 means the circuit breaker on this line needs to be 15 min safe at 20....
the fog machine is like a mircrowave and any major appliance needs dedicated lines not shared with lights or outlets besause it draws a lot of power to start and run and depends how long watts is simular to power the more light bulbs connect to a circuit breaker adds up 4 75w light bulbs adds up to 300 watts and that not includling outlets that may be connected....
not a gfci Unless dedicated at 20a....
Oct 17, 2008 | Kitchen Appliances - Others
No power in the frig ..no lights, no sounds, nothing
hmm. follow the power from the outlet to the point where you don't have it and fix the break in the circuit.
Aug 04, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
