Question about Keurig B30 Mini Coffee Maker
K-cups explode while brewing - Keurig B30 Mini Coffee Maker
2 Suggested Answers
advacak
  • 125 Answers
SOURCE: K-Cup exploded
shoot it and get a good one
a german name doesnt mean good
most of them are just proctor silex or toastmaster , with a european name ,and higher price tag on them
the best one out there is still the Bunn, and the company stands behind them
Posted on Dec 14, 2008
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
At the end of brewing it explodes water and grounds
Clean the Tubes that penetrate the Kcups. Use a needle or paperclip.
Oct 01, 2012 | Keurig B30 Mini Coffee Maker
Have had for 6 months with no problems. Recently have had coffee grounds both in the K-cup holder as well as the finished coffee in the cup. I used a different K-cup variety with same result. It's...
Hi, The bottom needle is plugged or missing...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 22, 2011 | Keurig Elite B40 Coffee Maker
I have 2 of these pots, neither of which will brew coffee. The water does not go up through the coffee grounds
Please be careful! Don't use them.
Mine did the same, and it exploded, destroyed my kitchen, my stove and my hearing!
Charlotte Furst, Sweden
Sep 02, 2010 | Vev Vigano Vespress Inox 3-Cup
We bought a Kurig Mini at this past Christmas. The machine worked great for about 4 months then the Kcups started exploding in the machine and coffee grounds would go into the brewed cup. Then the...
Mine has been doing the same thing.  I alkso received one at Chriustmas and it worked great for a few months.  Below is the answer I received from Keurig:
It is possible that the needle that penetrates the K-Cup has become clogged.  Please follow these simple steps to clean it:
Turn off the brewer and unplug it.
Reach under the nozzle (where the coffee comes out) and press up on the bottom of the funnel.  The K-Cup holder will pop out.
Separate the K-Cup holder into two pieces.  The top piece of the K-Cup holder is where the exit needle is located.
Use a paper clip to clear the exit needle by putting the paper clip in the tube on the underside of the holder. Be careful, the exit needle is sharp.
Wash the K-Cup holder with soap and water, rinse thoroughly.  Also make sure the drawer is clean.
Put K-Cup holder back into the drawer, making sure it snaps into place.
Plug the brewer in and turn on.
Run two cleansing brews (brew without a K-Cup) through the machine, and then brew a cup of coffee.
If you still find grinds in your coffee, it would be best for you to talk to a representative to help troubleshoot your problem and discuss your options.  This could be caused by too much pressure sealed inside the K-Cup or the filter alignment may be off.  Please contact our customer service department at 1-866-901-BREW (2739).  Representatives are available 7 days a week from 7 a.m. – 12:00 Midnight EST to assist you.  Please have the serial number of your brewer available for when you call.
The serial number for the Mini is located on the bottom of the brewer on a silver sticker.
For the Classic, Ultimate and Select, is located on a sticker behind the drip tray.
For the Elite, Ultra, Special Edition and Platinum it may be located either on the bottom of the brewer on a white sticker or, behind the drip tray.
Sincerely,
Briana Keene
Keurig Customer Service
At Home Division
(866) 901-BREW (2739)
csrah@keurig.com
Aug 25, 2010 | Keurig B30 Mini Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
K cup explodes
This happened to me with a B30. I called and they had me clean everything out thoroughly. at the very end the tech support lady explained the issue is with the kcups themselves. the ones with bulging tops have extra air in them that causes problems when brewing.
Mar 07, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
K-Cup exploded
Dec 13, 2008 | Keurig Coffee Makers & Espresso Machines
Keurig B30 Mini Coffee Maker Logo
1,446 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
