My compressor unit outside runs and cools Freon but the inside blower has a problem running. the model # is 2TEE3F31A1000AA. The fan control, in fan run control mode, shows a bright green for the fan LED and the CFM selection LED varies with the rotational speed of the fan. The motor tries to start showing , initially, a jerky back & forth movement. It squeaks some and may, or may not, start rotating. If it starts the CFM LED goes bright/on no flicker and the motor runs briefly (5 seconds) then stops.With the fan LED on the motor has resistance to turning (rotate from stopped state) and does not free-wheel. It has some rubbing sounds as you force it around. Last year we had a problem with water condensing in the AC-only unit in the attic during cold winter periods. The installer did not insulate the coil/filter box and water had condensed inside the unit. The iron core on the transformer, on the control panel, is rusty.
  • 1 more comment
  • ietbj Aug 30, 2010
    correction on the handler - it is a variable speed unit TWE031E13FB.
    Did you get my add-on that blower motor is a var speed, # TWE031E13FB?
    President:
  • 1,515 Answers
Hi, from what you have told me, you are loosing the bearings in this blower motor along with windings. This motor is rubbing the blower housing, tight when you turn it, and when it jerks when it tries to start tells me that you have burned or very weak windings. The run capacitor may also have failed causing this motor to try and start, but will not if this run cap has leaked oil, or has shorted and open internally. It will be a 5 to maybe a 7.5 uf microfared x370 volt run capacitor that should be mounted to the side of the blower housing. It will have terminals on top that the brown capacitor wires connect to. Look it over to see if the top or any where on it is swollen, cracked leaking out oil, or burned. This capacitor starts this motor and keeps it running up to speed. When a capacitor fails, it is usually caused by the blower motor over amping due to over heating because of the windings and worn bearings. You will need to replace both the motor and the run capacitor. By what you have told me the motor is doing, changing out the run capacitor alone will not solve your problem, as it also has bearing problems as it is rubbing. Also, you can get a roll of rubber back a/c tape with a aluminum backing to try and insulate the evaporator box better to prevent this condensation from ruining the controls and shorting more out. This tape is at Home Depot.Yes this motor has a lot of resistance and will not spin freely, due to worn and tight bearings that has caused this motor to over heat at some point doing damage before it could trip on its internal over load. When installing a new motor, depending on this furnace, the motor, blower housing and all with a couple of screws removed will slide right out so it can be taken out doors to remove the faulty motor and clean up the blower wheel as dirt collects on the wheel vanes causing drag and wear on a new motor as well as reduced cfm. If you are planning to take this on your self, mark all wires from the motor and run capacitor, and you may be able to find this motor at a retail appliance parts only house. If you know any contractors you can get one through a wholesale a/c parts house. Also, Granger's is a excellent place to get a motor open to the public and contractors. I wish you the best on this and I know for a fact that this motor is your problem, so replace it and the run capacitor and you will be up and running. Please don't forget to rate me and I know you will be kind to me. I will be checking in to see how it is going for you, so you can also keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 30, 2010
  • 1 more comment
  • Robert Horton
    Robert Horton Aug 30, 2010
    Hi, just to add something, this is a variable speed blower motor. When the unit in attic, the air handler, where this motor is, may have had some moisture get to it to start the process of damage to the windings. The evaporator coil will condensate all summer as long as the system is cooling properly. What will happen if its running and this blower motor stops, the evaporator coil will start to ice up rather fast as there will be know air flow through this coil causing it to freeze solid. Until you decide what you are going to do, the direction you decide, do not continue to run the unit as this will cause damage to other parts of the unit.
    Sincerely,
    Shastalaker7
  • Robert Horton
    Robert Horton Aug 31, 2010
    Hi, and I left you another comment to tell you this, that it was a variable speed motor. Even so, the rubbing, the wheel will not free wheel, spin, is telling me the motor is failing as it has stopped with in 5 seconds after starting, and bearings will cause this resistance. Replace the motor and run capacitor to solve this problem. This will be the solution and I know it can and will cost youu some $$$, but this will have to be done.
    Shastalaker7
  • Robert Horton
    Hi, and yes I already knew it was a variable speed blower motor just from what you were telling me from the stat and cfm's on the stat controller. Thank you,
    Shastalaker7
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Why is my new AC running all day and then losing a degree or two
Is outside unit running? If it is not that could be the reason. If it is running then you could be low on Freon. Check to see if outside is running if it is put your hand over the fan if its warm or hot the compressor is running if it is cool then your compressor is not running. Check this out because your inside unit will run even if the outside is not running.
Jul 07, 2014 | Heating & Cooling
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
Aug 25, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
