Question about Microwave Ovens
I can't get my clock set. I push options, 3 and 1, then when I put in the time, nothing happens. I need to know if I can use a ceramic turntable out of my old Microwave Convection oven. My oven is Model jes129osk 01, serial am900872n.
  • Microwave Ovens Master
  • 9,098 Answers
In case your owner's manual is missing, you can download it here.
If you're still having trouble after consulting the manual, please reply back.
The ceramic turntable (actually ceramic coated metal) will be fine as long as it doesn't have chips or cracks where arcs can occur.
Also, for even heating and longer turntable life, don't place your food in the center, but slightly off-center instead.
If you need to order a new turntable, enter your full model number JES1290SK here http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
How to set time
usually you push clock, put in time, push clock, click am/pm to whichever it is, then push clock again. That should set it.
Apr 30, 2012 | Microwave Ovens
When I set the time --- it just ticks and nothing comes on
Hello ebrunsw. Generally to set the time you push clock and then set the time AND then push clock a second time. Joe
Thanks for choosing Fixya!
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
Toshiba micriwave time setting
These manuals are no longer available, but maybe one of these key combinations will work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Please let us know how it goes.
Nov 04, 2008 | Microwave Ovens
Farberware Microwave Oven
Try getting help via e-mail to farberware-electric@saltonusa.com or by calling 1-800-233-9054.
In most cases, you press Clock, then the numbers, then either Clock or Start.
Oct 26, 2007 | Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
