Question about Northstar Pressure Washer 2800 PSI
I have a northstar 2800psi 2.5gpm washer that doesn't pick up the cleaning soluion, is there an adjustment to make it **** the fluid out more?
  • 30 Answers
There isn't an adjustment for pulling the cleaning solution out faster or slower. It's an automatic function, based on the size of the power washer (meaning it ****s at different rates for different sized washers). Here's a link to the manual for more information:
http://www.northerntool.com/downloads/manuals/1577543.pdf
Hope this helps!
Posted on Aug 30, 2010
Windshield washer fluid does not spray on my. Windshield
Sounds like the spray nozzle is bent or partially plugged up.
Jan 05, 2013 | 2001 Mazda Protege
Engine will not run with out choke being puh in
You will need to remove the carburetor and clean. Be sure to clean the high speed jet. This jet is the bolt that holds the fuel bowl on. Remove and clean the small holes in the sides of bolt. You will need a small piece of wire or bread tie just remove the outer covering and run this through the holes. Some have a hole in the bottom and smaller hole in the threads towards the top. Clean with carburetor cleaner and blow with compressed air. Try cleaning the jet first and if this doesn't work then clean and rebuild entire carb. Hope this helps.
Jul 23, 2011 | Northstar Pressure Washer 3000 PSI
I can't get the machine to siphon the cleaning solution.
This is usually caused by either a plugged siphon line or if you are using the high pressure tips (red, yellow, white or green) on the wand. Check that the siphon line doesn't have any debris or bugs in it. The only way the siphon hose will work is if you use the low pressure, black soap tip on the end of the wand. The other tips cause too much back pressure for the cleaning solutions to be picked up by the hose.
Apr 26, 2011 | Northstar Garden
I picked up my NorthStar 157892A Powerwasher from a family member, they lost the manual and its tune-up time. How can I get a replacement manual?
I would recommend that you call northern tool at 1-800-270-0810 and let them know what you need. I have found them to be very helpful and knowledgeable.Hope this helps you. Thank you.
Mar 23, 2011 | Northstar Garden
Troy-Bilt pressure washer will not pick up cleaning fluid
put the washer on low presure it will pick it up then. doesn't make since but that is how they designe them. thay make a high presurre add on device i have seen them them in local home inproverment places.
Jul 20, 2009 | Garden
Unable to start gas engine on a NorthStar pressure washer
Disassemble and clean the carb. If it ran briefly with the starer fluid then gasoline is not coming through the carb.
Dec 30, 2008 | Northstar Garden
Northstar Pressure Washer 2800 PSI Logo
144 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
