Question about HP PSC 1315 All-In-One InkJet Printer
Printing Problems with an HP LaserJet All-in-One
The printing on some areas of the page is blurred, as if the printer cartridge is hiccupping at a certain point and then continuing on. The blurring occurs in the same area all the way down the page.
    Novelist:
  • 170 Answers
This sounds to me like a fuser issue or something may have gotten caught on the toners photoreceptive drum...check the toner first, if not replace the fuser...
Posted on May 08, 2008
HP CP1215 Printing is blurred
should of included a pic of print.
Blurred prints are usually fuser related.
Nov 15, 2016 | HP LaserJet CP1215 Color Printer
Black line scan
Sir
Checking the print cartridge
Image formation defects are many times the result of print cartridge problems. If there is any doubt, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Or Go To Below Link To Find all The HP Printer Help For Your HP Printer Problems
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-bpl70340-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1390257139382.876444892.492883150
In Case You Need Help Then Follow Us On:
HP Printer Support
Jan 20, 2014 | HP LaserJet 1100a Printer
My hp laserjet m1005mfp printer is not printing document while i replace its cartridge twicely so give me solution urgently
Image-formation defects are frequently the result of problems in the print cartridge. If the source of the defect is not immediately evident, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to make sure that the print cartridge is still operable.
? Make sure that the print cartridge is seated properly.
? Check the print cartridge to see if it has been disassembled or refilled.
? Inspect the print cartridge to see if toner is leaking through worn seals.
? Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or
and image defects.
? Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been
To redistribute the toner in the print cartridge
Before installing a new print cartridge or when the toner begins to run low, redistribute the toner by
rotating the cartridge back and forth five or six times.
Jul 22, 2011 | HP LaserJet M1005 Printer
My laserjet printer started making load noises and no longer prints-the last thing printed only printed the top 3inches and then was all black, it then stopped working altogether
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- raaj_k001@rediffmail.com
Jan 12, 2011 | HP LaserJet 1200 Printer
When printing a page. I get a large shaded area
umm
you may know that this model of printers is very old
i think your cartridge is expiered try to change the cartridge if by the old one just to test....
if the new cartridge is the reason then you have to replace it
Feb 19, 2010 | HP LaserJet 4p Printer
Smudged printing. Ink cartridge just replaced.
This is a laser printer and does not have a print head to be cleaned. Fortunately it does have a laser cartridge that can easily be replaced and solve all of your problems : ) The replacement cartridge is a HP Q2613A or the high capacity HP Q2613X. Your local Cartridge World should have a high quality refilled cartridge that will treat you very well and save you money.
Jan 03, 2010 | HP LaserJet 1300 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
HP 5l laserjet printing problem
AoA
dear sir
our printer not printing correctly. it print some other language in top of the page. please solve my problems
Aug 03, 2008 | HP LaserJet 5L Printer
HP Laserjet 1200 not printing in one area
your fuser is truly unhappy..time for a new fuser
May 28, 2008 | HP LaserJet 1200 Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
