Question about Vacuums
I need a manual for a prestige 50507 mini blender
Where to find tristar blender model yd 208 motor
Do a web search and type in Tristar Blender Model yd 208 motor. If you can get the part number from your old one, that'll make the search even easier.
Aug 29, 2014 | Vacuums
GE blender model 169169 jar broke, trying to find out where to buy replacement picher (glass)
I have the jar since my motor base stopped working. Make me an offer and I'll mail you the blender jar. Tom
Sep 03, 2011 | Vacuums
I'm looking for a service manual to open up the blender, which is Cuisimart cb-56. Any help would be appreciated. Francis
I think the owners manual is all you ever get for any appliance
If you take it apart, your on your own
Aug 06, 2011 | Vacuums
How do you remove the coupling on model kichenaid ksb560mco. it doesnt spin off like some online instructions say.
It should spin off when you stop the motor from turning. Use a long flat bladed screwdriver positioned against one of the teeth of the coupler on the angled side of the tooth. Then hit the screwdriver with a hammer to drive it into the plastic tooth without breaking off the tooth. (Note: it's a left-handed thread, not the more common right-handed thread. So you need to turn it clockwise to loosen.)
The hard part is getting that motor connection to stop turning with the coupling.
If you want to save the coupler and some damage to the blender when the screwdriver slips, get the blender coupler removal tool. See http://www.kitchenaidblog.com/blender/kitchenaid-blender-rubber-coupler-9704230-with-removal-tool/ for a link to buy both. Slide the removal tool under the old coupler to hold the knob from turning. Then turn the coupler to remove it. For some a pair of pliers helps you start the coupler moving. (It can get stiff over time.)
I hope this helps.
Jun 26, 2011 | Vacuums
The piece under the blades cracked can it be replaced with out buying the whol blender
You can try removing the blades and put apoxy in the crack and let it dry. Put the blade back on and make sure the blade does not rub by turning the blade by hand to see if it turns smoothly. Do all of this while the blender is unplugged.
Mar 11, 2011 | Vacuums
Wherecan I find a prestige pressure cooker manual
What is the model number of the pressure cooker that you require the manual for?
Dec 23, 2010 | Vacuums
How to put bottom blade of blender back after cleaning
Drop blade in from the top.there should be a notch that blade fits in or it should screw into bottom piece that drives the motor of blender
Oct 21, 2010 | Vacuums
I need a manual for a JL Mini sewing machine.
This can be obtained from a site called:
www.sewingmanuals.com.They carry manuals for many make and models and if they do not have the one you need you can also try:www.manuals.comI hope this will help you and good luck!
Have a good day!
Oct 13, 2010 | Vacuums
Got this blender in 83 and the pitcher is cracked. Model 600-1. Can I get a replacement?
You may be able to get one from the manufacturing co. or you may find a blender with a pitcher that fits at a yard sale, flea market, thrift shop or Good Will. However, blenders are not that expensive and after 26 yrs you may soon need a new motor. Now may be a good time to replace it. If its sentimental, keep it but get a new one.
Nov 03, 2009 | Vacuums
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
