Question about Ruud UAKA018 Air Conditioner
My ac unit won't turn on. a couple of nights ago, we had the opposite problem. thought (hoped) it might just be the thermostat which I replaced an hour ago. didn't seem to help.
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 31, 2010
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Two winters ago i had to change out my thermostat. Then last summer my AC wouldn't turn on. So i thought it was the thermostat i had so i just went and bought a better one. but still the Fan on the AC...
If the compressors running and the fan is not you should check the fan motor capacitor and check for power at fan motor if power is there you have bad fan motor
Jun 21, 2011 | Heating & Cooling
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
LG window AC turns on and off by itself
replace the thermostat is the element starts and stops the cooling( compressor)
or replace the selector switch if all unit is cycling on and off
Dec 03, 2008 | LG Electronic Window Air Conditioner
Air conditioner
Yes, first turn your thermostat to the off position. Try to reset both fuse boxes again. If the ac comes back on problem solved, if not fuses and or breakers may need to be replaced. Let me know if this helps and we can go futher into why the ac is not only reaching the temp at night. Thanks
Aug 10, 2007 | Haier Energy Star ESA3183 Air Conditioner
Ruud UAKA018 Air Conditioner Logo
53 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
