Question about Nintendo DS Console
Hi there. My DS was sat in a draw for a year or so, and now when i come to turn it on, it asks me to adjust the system settings. Following the completion of this, it restarts. Upon restart it asks me to 'adjust system settings' again, and the cycle just repeats.
  • 4,102 Answers
Hi, this is a common problem with ds, that happen if they have been sitting around for a while. they have a small watch battery inside that keeps the time and date running now since it has not been charged or used for so long then it looks like this battery has gone flat, you can try giving it a full charge and see if that makes and difference if not then your going to need to get the internal battery replaced, if you take it into most small phone shops they will be able to do the repair for you.
tell them the problem your having and then they will get this battery replaced for you.
try giving it a full charge first and let it go flat then charge it again if that still dont work after this then it will need a new system battery.
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 30, 2010
  • mikemoney
    mikemoney Nov 19, 2010
    thats a great soulition
How do you set the time and date on blood pressure monitor model DS-1902
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped. Thank you
Jan 15, 2011 | Mark Of Fitness DS 1902 Blood Pressure...
Re:-DS Lite.WiFi set-up. Asked for a Access Point. Came up. '' This access point's security settings are not supported by the Nintendo DS.'' ? It was accepted on my Wii?
The DS lite only supports WEP which would have a HEX key password, if you have a pass key or pass phrase then chances are you are using WPA or WPA2 which is not supported on the DS lite.
The WEP key is an older form of security and has been found to have some weaknesses but to be honest its still secure enough for a home wifi set-up.
Here is a link to an article explaining more about the differences between the two.
You can change your settings on the wireless router, but you will then have to adjust the settings on your Wii accordingly.
If you need any further help or advice please feel free to contact me via my profile page.
Regards,
SOD69
Feb 16, 2010 | Nintendo DS Lite
I wanna program my urc3021remote to my ds coverter box but cant find the code
You may want to try searching for the ds converter box code for your URC 3021 remote automatically. These are the steps:
  1. On the remote control, press CBL/SAT once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the converter box and slowly alternate between pressing POWER and CBL/SAT. Stop when the converter box turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Sep 27, 2009 | One For All URC-3021 Remote Control
1990 yamaha virago 535 sat two years
If it is possible to start at all. Fresh fuel fresh engine oil good battery. You may have the following problems; Corroded and blocked carburetor fuel system, bad wire connections piston ring set up.... I hope it was kept indoors and the fuel was drained out before it was left sitting. Good luck, they are nice bikes.
May 29, 2009 | 1989 Yamaha XV 535 Virago DX
System settings won't save... Nintendo DS
hi im 9 and i can help you save your settings by turning off the ds and then try to save everything you need and then dont shut close the screen there you go. and fold it back up and it saves
Feb 07, 2009 | Nintendo DS Console
WELCOME SCREEEN PROBLEMS
You probably damaged the main circuit board and the settings like the date cant be saved properly so after reboot it thinks something has happened and wants you to re set settings and happenes again and again.
Oct 07, 2008 | Nintendo DS Lite Console
Time Date
Clean your battery contacts and DS pins with alcohol.
If not working then you have a deffective mainboard and need to take your DS to warranty or repair.
Jul 07, 2008 | Nintendo DS Lite Console
Thing goes to game instead of the menu bar when DS game is in.
you can set the ds to auto load the game from the options menu, so turn off the system take out the game cards (both DS and advance games) and then turn on your system, that should cause your system to start displaying the pictochat/ ds download play screen at the bottom of this you will see a ds pic tap that and you can get into your settings and change them from auto to manual.
Hope that helps ;)
Dec 07, 2007 | Nintendo DS Lite Console
Won't power up-flash of light on bottom screen then nothing
if yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Nov 27, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
693 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
