Question about Cannon Woburn 10560G / 10562G / 10565G Gas Range
Cannon cooker woburrn ignition switch model - Cannon Woburn 10560G / 10562G / 10565G Gas Range
How do i change the ignition battery my gas cooker
Our battery compartment is right down at the bottom of the cooker so I have to lay down and use a torch to see and a small Allen key to release the battery cover...
Nov 02, 2015 | Cannon 10476G Dual Fuel (Electric and Gas)...
I Require A Manual For A Cannon Worcester Cooker
Did you try a search engine yet?
"Cannon Worcester Cooker manual" took me right to their website.
http://www.cannonservice.co.uk/hs/pages/content.do?keys=FAQ:PAGE
http://www.cannonservice.co.uk/hs/pages/manual/manualSearch.do
Enter "worcester" for the model and voila!
Sep 04, 2011 | Cycling
The clock has stoped working on my cannon chesterfield cooker, why!!
i have the same cooker (in brown colour) and is just 3 years old. The clock was coloured green and over the last 6 months or so has gradually faded to no illumination at all. Then it started to buzz very lightly when the mains was switched on to ignite the gas. In August 2011 phoned Cannon Indesit repair line on 08448 224 224 and agreed to pay £104.99 for call out and labour to fix. The parts are covered for 5 years so no charge for the clock. Engineer took 22 minutes to replace the clock which is now a deep yellow colour and much easier to see in the daytime.
Sep 03, 2011 | Cannon Chesterfield C60G Kitchen Range
I have a cannon lincoln model 10255G ignition has stopped working how do i fix thanks
Hello
Replace battery.
It's similar to a watch battery found at the base of the cooker front.
You will need a flathead screwdriver to open casing.
Good luck.
Apr 02, 2010 | Cannon Kitchen Ranges
Bottom oven on Cooker Cannon c60gcw will not ignite, continuouos sparking and no gas when knob turned on
Fault caused by trapped and therefore cut wiring to main oven valve at bottom rear of cooker causing wiring overheat melting and open circuiting electrical supply.
Sep 15, 2009 | Ovens
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
The clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Dec 05, 2007 | Ovens
Cannon Woburn 10560G / 10562G / 10565G Gas Range Logo
50 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
