Question about Refrigerators
Admiral ref with freezer on top I need to find out how to get to defrost heater so I can test it
Can anyone tell me how to get to the defrost heater / stat so I can test it.model number nt19L6
  • 828 Answers
Defrosr heater is located behind the back wall of the freezer section. You will have to remove the shelves and ice maker if you have one installed. A number of screws secures the back wall in place. Remove the screws and the back wall should pivot out from the top.
The defrost thermostat is located behind this wall and is secured by a clip to the coil. To test this defrost switch you must lower its temperature below 16°F.
Posted on May 09, 2008
I have a" Admiral designer series model HMG24922" Refrigerator, And the freezer keeps leaking out water can anyone tell me how to fix it!??
if it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Apr 08, 2015 | Admiral Refrigerators
We have a Admiral Top Freezer Refrigerator Model#
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Nov 02, 2013 | Admiral Refrigerators
Admiral frige/freezer icemaker not working...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 10, 2011 | Admiral Refrigerators
Yes i have a admiral model number nt19c5st the freezer seems to work fine but fridge dont cool it is a top freezer can you help me ?
NOTE: This
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Leo Ponder
imufo2
Aug 07, 2011 | Maytag Admiral Top-Freezer Refrigerator
Back of freezer ices up .refridgerator warm... Fan is OK..... Top mount freezer
There are 3 things to look for on this. The defrost timer which tells the ref. to go into defrost, the defrost t-stat which sends power from the timer to the heater and then the heater. Most likely out of the 3 it is usually the t-stat located on the evap coils behind the back panel of your freezer section. Easy to get to and easy to change. The stat is the one item that has a wire going to the heater. Hope this helps.
Feb 02, 2010 | Refrigerators
I have an admiral model HMG 67184 side by side and I can't figure out why my freezer section still works but doesn't get cold enough to make ice cubes and the other side doesn't work at all. I do have...
1. Get the Food out of the Ref and Freezer. Unplug the power cord from the wall.
2. The cooling coil is in the back wall of the freezer side. Working from inside the Freezer.
3. Remove the back plastic cover to expose the cooling coil. It's called the Evaporator coil.
4. Use a hair dryer to melt all ice off the coil.
5. Put it back together. It should work for 3 - 5 days now at least.
6. Put a thermometer in there. After 24 hrs. the freezer should be 0 to 10 degrees F. and the Ref. side 37 to 44 degree F.
7. Check the door gaskets for tight fit, using a dollar bill for a gauge.
Shut the door on the dollar and try to pull it out in several places.
If it ices up again in a week or two, you have a defrost heater problem. There is a electric heat strip around the cooling coil. This heat strip comes on about 10 minutes every 8 or 10 hours. This heater melts the ice off the coil. There is a clock timer device under the ref. that cycles the heat strip. You may have a bad clock, fuse device or burned out defrost heater strip. The cooling coil must be ice free to work properly.
Jul 06, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator not cooling
unplug appliance, melt ice on back of freezer, remove panel rear of freezer, find leads to defrost heater and test with a multimeter, if you have condinuity replace defrost termostat, if no condinuity replace defrost heater. after removing panel you will have to melt ice in rear with heat gun before testing.
Jun 22, 2009 | Admiral Refrigerators
We have an Admiral top freezer refrigerator. Freezer is working refrigerator is running at 60 degrees.
If there is no ice on the back wall of the freezer, make sure the freezer fan motor is running. If there is ice on the back wall of the freezer repair the defrost components. Timer,heater,thermostat.
Jun 09, 2009 | Maytag Admiral Top-Freezer Refrigerator
Fridge not getting cold
you have a defrost problem.when you open your freezer door and look at the back panel look and see if their is frost built up.if so that means you do have a defrost problem.you will need to pull panel off and defrost coils.then you can check your defrost thermostat which is round and has 2 wires that go to it.it sits at the top of coils.see if it seperated.if so that is your problem also check defrost heater see if any breaks in it.if those check out then could be defrost timer which is located in ref.side.it would help to know what brand it is.it sounds like a side by side ref,but dont know what brand.
Mar 24, 2009 | Freezers
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
