Question about Dryers
Unit runs but does not heat - Dryers
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Air conditioning worked all summer and now heat will not come on and outside unit will not run
Is this a heat pump or straight cool with heat strips. If straight cool the outdoor unit should not run in heat. If heat pump, did it work last year? If it did and now the outdoor unit will not run you likely have a bad control board. Possibly lost your settings in your tstat... check the stat first, make sure its configured for HP
Mar 17, 2017 | Heating & Cooling
When em heat is on my outside unit runs but when not on em heat it doesn't. Which setting is best to use?
Has this always been this way? When the emergency heat is on the outside unit shouldn't run. When in normal heat, no emergency heat, the outside unit should be running unless the temperature is below the balance point ( usually around 35 degrees). If this has always been this way and the outside temperature is above 40 degrees you might have your 1st stage and 2nd stage wires switched.
Nov 27, 2016 | Heating & Cooling
Icing up outside. no heat inside
Isolate unit to defrost out door unit,
Once defrosted run unit ensuring heat from unit inside and fans are running outside,
if fans and compressor are running and there is next to no heat inside coming from indoor unit this is a common sign of a refrigerant shortage in system and this may cause outdoor unit to freeze up
Jan 24, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
Running high head pressure in heating cycle runs fine in a/c cycle
Check your indoor air filter. When the unit is in heat pump mode the indoor unit is cooling the air, ie. removing the heat from the unit. If the air flow is restricted then the unit will run high head pressure. If the filter is clean then maybe something else is restricting the air flow of the indoor unit. The other possiblity is that the unit is over charged. When in cooling the overcharge will not create the problems that it will in heating mode. The only proper way to charge a heatpump is to remove ALL the refrigerant and then wiegh in the proper amount of refrigerant into the system.
Nov 19, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Dryers Logo
24 people viewed this question
Top Dryers Experts
