Question about GE Dryers
Model # dbxr463eg1ww, dryer overheats and stops sometimes, only on reg heat, after cools off starts right back up. Sometimes it goes thru cycle and sometimes it stops again. Top of dryer gets very hot to the touch(almost burning hot). On other cylces operates just fine.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Maytag DE810 Dryer takes too long to dry
Have you checked the Hose and the pipe that exits your wall? Sometimes birds will nest in them. Pull the dryer out and run it without the hose connected to test it.
May 18, 2015 | Dryers
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Dryer starts out hot but sometime during the cycle it turns cool and does not dry the clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool WGD5320SQ Gas Dryer
I have a gas Frigidaire dryer that heats once or twice
your cycling/hi-limit switch needs to be replaced,it is located on the outside of the burner tube to avoid an overheat condition and cycle the flame according to your heat setting on the control panel
Mar 14, 2010 | Frigidaire GLGQ332A Gas Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
No heat in indesit dryer. cycles as normal
Hi
remove back panel and with a mulitmeter check the stats to see if open circuit if so replace and should be back to normal.
regards
Mar 12, 2009 | Dryers
Items in dryer are not quite dry, cool down cycle is real short, heat is maintained in dryer when it stops and wrinkles clothes. Cool down cycle went from 4 minutes down to one, skipping 3 and 2. Same...
check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Mar 08, 2009 | LG DLE5955 Dryer
Dryers Logo
156 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
