Question about Xerox DocuColor 12 Color Copier
I got a Error code 9-343
We change the pressure roller and then after turning on the copier it gives me the error code 9-343
    Scholar:
  • 53 Answers
Any 9 -xxx code is related to the xerographic area of the machine NOT the fuser area- you don't mention the model number so I can't be specific, but try the Drum/CRU/toner area, make sure you haven't dislodged anything (modules, plugs, sockets etc.)
Posted on Jun 01, 2008
Testimonial: "Thanks i could fix my problem."
  • ashish Mar 18, 2015
    Sir i have only one machine and face this error code.when i switch on the machine and this error show.so please help
When my konica minolta c280 gives me an error codes c2151 please help"
Code
C2151
Description
Secondary transfer roller pressure welding alienation
• The pressure welding alienation sensor doesn't turn OFF (retracting) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is retracting. • The pressure welding alienation sensor doesn't turn ON (pressuring) even after the lapse of a given period of time after the 2nd image transfer pressure retraction motor has started rotating during the 2nd image transfer roller is pressuring
Sep 23, 2016 | Konica Minolta Bizhub C280 Color Copier /...
Konica Minolta bizhubc552 error c8102
Here is the error code definition: C8102 Turn around pressure welding alienation trouble
•During a pressure motion being performed, the reverse roller sensor (PS7) output does not change from H to L. •During a retraction motion being performed, the reverse roller sensor (PS7) output does not change from L to H. Further research yields this possible fix, since this model is in the same family as yours: http://www.copytechnet.com/forums/konica-minolta/89213-konica-minolta-bizhub-452-error-code-c-8102-a.html
Apr 06, 2015 | Konica Minolta Office Equipment & Supplies
064 code
Symptom
E064 is indicated on the control panel. The error description is: The presence of a high voltage error is communicated by the composite power supply. The output for primary charging, developing, or transfer has deviated from a specific level of voltage.
Cause
* Adjustments in Service Mode are Incorrect
* Transport Assembly is Not Engaging Properly
* Dirty HVT Contacts for Developing Assembly and Charging Rollers
* A Paper Clip on HVT Contacts or Developing Assembly
* Faulty Transfer Roller
* Faulty Static Charge Eliminator
* Defective Composite Power Supply
* Defective DC Controller PCB Assembly
Action
1. Check the values in Service Mode and make sure they correspond to the Service
Label. If the copier receives a spike or surge through the 240V line these values can change (can also give you blank copies). Take particular note of the Dev Bias
setting. [COPIER > ADJUST > DEVELOP > DE-DC]
2. Make sure the Transport Assembly is engaging properly. The Transfer Roller should
make good contact with the drum. Check condition of screw (XB6-7501-007) and
Pressure Plates (FB5-4816-000 & FB5-4817-000) for the Transport Assembly.
3. Clean HVT contacts for Primary/ Transfer Charging Rollers and Developing
Assembly. Inspect for any paper clips.
4. Replace the Transfer Roller (FF6-0104-000).
5. Replace the Static Charge Eliminator (FF5-7246-000).
6. Replace Composite Power Supply followed by DC Controller PCB Assembly
Thanks
Dec 17, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Ricoh Affcios 3025 Functional problem with copier
Hello!
This code is related to a Fusing temperature error.
You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do not have technical knowledge)
If you still want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 04, 2011 | Ricoh Aficio 3025P Black and White Copier
Hello i have a canon CLC 5100 and it giving me an 840-0001 error code can some one help me
When the machine tries to more the
roller, there is no change in the signal
from the external the HP sensor 1
(PS9003) after it has started the
external heat roller drive motor
(M9004
Probably you have faulty on the external heat roller drive
motor (M9004).
Jul 10, 2010 | Canon IMAGERUNNER 6570 Copier
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir3170ci - error e000008-00001
This is a fuser roller life error. The machine has an internal counter that counts parts' usage. This code can only be reset by a technician.
Mar 25, 2009 | Sharp AR-C160 Color Copier
I have a Toshiba E-studio 650 with a C46 error code.
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
Jan 10, 2009 | Toshiba E-STUDIO 650 Copier
Xerox DocuColor 12 Color Copier Logo
353 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
