Question about Linksys Wireless-G WRT54GR Router
I have a wrt54r i just changed moved cant get router to connect
My d link router green lights are flashing contineusly and cant connect with my device.cant connect with my mobile or my computer
Ok, there might be one possibility.
Someone might have hacked your router and banned your devices from connecting. Yes, it can be done especially if you are using WEP to connnect to router.
Hardwire to your router using a cable and log in. See what other devices are connected, you also might want to change the wireless SSID name and password, however, do not use WEP, change it to WPS-PSK which is a lot harder to hack.
Feb 16, 2014 | D-Link Wireless N 150 Home Router 4Port...
I cant get my Acer 5250-BZ873 to keep a wireless connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 23, 2012 | Acer Aspire 5100 Notebook
I cant move my acer aspire 2610z to a different location. It has to be connected to the modem. How do i change this?
If you had a router just plug it in your modem.If not try to buy a router so you can use your PC in wifi.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | Acer Computers & Internet
Cant connect to 192.168.1.1 to change the settings for my wireless router has i have moved house
You may either need to connect via a cat5e (hard line network) directly to the router to access the options. If it still fails to allow you to connect try hitting the reset button on the back to revert the router to it's original configuration and unplug it afterwards for about 10 seconds for good measure.
Aug 06, 2010 | Office Equipment & Supplies
When i plug in my router the ip address changes and i cant access net
This issue is possibly due to a configuration problem
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Here is the link for the DIR-330 your model number did not list:
http://www.dlink.com/products/?pid=564
Jun 21, 2010 | D-Link DIR-300 Wireless Router
I cant seem to pick up a very strong signal. Do i need an antenna booster?
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Lose internet connection when phone is in use
Your cordless and wireless mode is running on same frequency.
You can do couple of things...use the wireless mode in b instead of g in the router.
Else use a different cordless phone which runs in 5.8 or 6.0 frequency.
Hope this helps.
-Pankaj
Mar 26, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Wireless connection
First thing to check is if there is a firmware upgrade for your router.
Afterwards and depending on your model, you can also increase the signal power on your router.
Or you can try changing the channel from 1-11 to see which one works best.
You can also:
move the PS3 or router closer together
use a wired connection
get a stronger router
etc.etc.
Hope this helps.
Mar 04, 2009 | Sony Playstation 3 (PS3) Console
Cant connect to the internet!!!
well first i can suggest trying to reinstall the drivers for the ethernet controller and the wireless card you are using. if that does not solve the problem, then are you subscribed to internet through cable, which is what your router connects to?
Jan 05, 2008 | Dell Latitude D600 Notebook
Linksys Wireless-G WRT54GR Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
