Frequent disconnection using D-Link DIR-600. If I reset the router, it comes back. Also, if I plug the laptop directly to the modem, there is noproblem at all. Is there anything I can do to prevent this disconnection? Is it my DSL connection or is it a router problem?
I had the same problem. In manual wireless setup change mixed mode b,g,n into g. That solved it for me. All my laptops are g.
Posted on Jan 09, 2011
  • cyberkur75 Jan 10, 2011
    i have also dropped beacon interval in advaced->wireless settings to 20.
  • jamessmit272 Jan 17, 2011
    i also faced the same issues which you are facing and my friend told me about "ijinni technician" i contacted them at WWW. Ijinni. Com for any issues Just open the website and you can chat with the experts who are Microsoft certified technicians and will fix the issue itself on the spot or u can call them through Skype or contact and for more visit their website as it is very user friendly website. Just click on the chat as the response rate will be very fast from them and they have fixed my issues in no time.
    There are 4 ways to reach them.
    1. Once you open the website just click on the live chat where one of the IJINNI technicians will be in touch with you.
    2. If you have Skype installed in your machines just add the contact "ijinni.com" (free call).
    3. You can email at support@ijinni.com.
    4. You can dial at 1 512 879 3546.
    For any issue you are facing with the computer just call IJINNI
Option 1. Change the Channel to 9 and check, if it doesn't work change to 11/6/1 and monitor each channel.
Option 2. Change the location
Option 3. Check for any microwave oven or anything near by , which may cause wave interference.
Posted on Jan 23, 2015
My dlink 600 cant give blue solid color so its not functioning
Have you tried a reset? Have you checked/reseated ALL the cables? If you use a Ethernet cable directly from the ISP modem. or the D-Link, does it work? Perhaps the D-Link is bad, it's hard to say without eliminating the components one by one. Try D-Link Support for a user manual : http://www.dlink.com/uk/en/support/product/dir-600-wireless-n-150-home-router
Apr 07, 2013 | D-Link DIR-600 Router
D-Link DIR 600 connection problems
If this is the case, there is no problem with the router. the problem is with the modem.MAke sure that the cable from the modem goes into the WAN(Internet) port of the router.And also, what kind of internet are you using? is your router set up properly to work with your provider?
Is there any problems when you connect your pc to the modem directly with the cable, or does the problem occur only in the wifi connection?
Feb 18, 2012 | D-Link DIR-600 Router
Ever since the storm I can't get online wirelessly, I can't get on with the internet cable direct but not with the dlink 600. Please help.
check
1.- Cable leave modem is attached to Port WAN (they are others 4 ports LAN)
2.- In router Dlink DIR 600 led Internet in On or blinkling
3. using web browser type http://192.168.0.1 (this is IP default )
4.- reset your DIR600, using a clip press in reset Hole 10 seconds
5. Try again using web browser type http://192.168.0.1
If connect, re configure your modem for your wireless network
Sep 14, 2011 | D-Link DIR-600 Router
Pressing the reset button doesn't reset router (D-link DIR-600) to default settings. Router is connected to a cable box and to my laptop with ethernet cable. Should I disconnect router from cable box?...
try pressing and holding the reset switch for 15 secs. pressing and holding initially restarts the router. pressing and holding it further resets it back to its default settings.
good luck!
Sep 12, 2011 | D-Link DIR-600 Router
Dir 615 stopped connecting to internet....wireless connects laptop to internet
locate the reset button on your router then push it gently hold for 10- 15 sec. then connect it back to the modem
Aug 04, 2011 | D-Link DIR-600 Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
Why i can't to inernet using my router?
Reset the router and make sure all cables are plug-in then see activity on the light. If you don't get WAN light then contact your ISP to verify the account info.
Mar 05, 2011 | D-Link DIR-600 Router
Hello. I have a Dlink dir 600 router and it worked without problems for about a year (usually there were 2-3 laptops wirellesly connected to it). Then suddenly I couldn?t connect to the internet anymore....
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 13, 2011 | D-Link DIR-600 Router
I have a Tata Wimax broadband, i have got a D-Link DIR 600 Router, i have tried so many times to go through both easy setup CD and Manual setups but invain.. i am frustrated!!!! I am able to connect to...
Ok...don't panic....take it all back out thru control panel>add/remove...reset your wimax modem by the little reset hole in the back as this can be an issue sometimes by adding the modem in the incorrect order. You should install everything but the "lan" cord from modem to modem last. A good test is to take the "lan" cord from your winmax modem and plug it right into your pc and you should have internet.
Jan 03, 2011 | D-Link DIR-600 Router
Computers & Internet Logo
904 people viewed this question
David Payne
David Payne
