Question about Dodge Car Audio & Video
I have a 1996 stratus and a wire touched a metel part behind my radio now my radio, dome light, mirrors, and power locks are not working. i checked the fuses and all of them are good.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dodge Master
  • 2,226 Answers
Did you check both fuse boxes??????? there should be a fuse box under the dash or in a kick panel and there should be another fuse box in the engine compartment.
Posted on Aug 30, 2010
2000 Stratus no radio power locks don't work and dome light don't work.
Check battery connection. Unhook for 10 minutes, hook back up.
Mar 29, 2016 | 2000 Dodge Stratus
Location of relay for radio and dome light and power locks
There is no relay covering all 3 of these! Most likely a fuse blown, check fuse box inside and under hood of vehicle!
Jan 01, 2016 | 2000 Dodge Stratus
I have a 1997 Dodge Stratus and my power locks, power mirrors, radio and dome light all won't work. All of the fuses are fine. I have no idea where to start.
Without wire colors and schematics. It is hard to start anywhere. You need them. You need an OHM/VOLT meter also. Alldata and Mitchel have good wiring schematics. You get the stuff you need and post schematics, I will walk you though to fix them.
Jun 10, 2015 | 1997 Dodge Stratus
I have a 1996 Dodge Stratus. The Dome light Won't shut off. It used to turn on and off with the door open and shut. what is going on? I have to move the switch to the driver's side to shut it off. The...
check for a door switch that the wire is touching the metal door frame and leaving the light on regardless of whether the door is open or shut.
Feb 20, 2015 | 1996 Dodge Stratus
My dome lights mirrors or door locks want work if i have my door cloosed but if i turn dome light switch all the way on with door open it all works if i cut my dome light switch off with doors open mirrors...
It's some kind of short. my guess either the wiring in the boot between the door itself and the frame/ body. or possibly in the circuit for the door courtesy switch, lastly the dome light circuit. if you have a test light, probe for a faulty circuit (grounding or incomplete)
Aug 21, 2013 | 1996 Mercury Cougar XR7
Dome light, power door locks, radio not working
Hello! Check fuse #11 (15A)...Are your Mirrors and Wipers working? If that fuse is good and mirrors/wipers with dome, door locks and radio are not working it looks very much like a defective Ignition switch...send a comment...
Guru...Saailer
Nov 27, 2011 | 2004 Chrysler Sebring
Interior wiring in drivers door. Radio, mirror lights, dome light on console, trunk light, power door locks and electric mirror switches don't seem to work. I suspect a fuse, #4 20 amp. under the hood and...
do you have an aftermarket stereo? if you do, unplug it and see how long the fuses last. check your lighter and make sure there are no foreing object in there that can cause a short. when you replace the fuses, take notice of which action causes the fuses to blow... for example, door lock unlock, are they still ok, door lock, lock..check again, mirror left, still ok, so forth and so on. take it one at a time and see which action causes them to blow. when they blow do it again to see if the same action that caused them to blow the first time did it again, then trace those wires. you probably have a bad relay somewhere.
Oct 06, 2009 | 1996 Chrysler Sebring
2003 ford escape, fuse keeps blowing for door locks, radio and dome light. y
check for a shorted to ground positive wire repair as nesseacry
Jun 01, 2009 | 2003 Ford Escape
Car Audio & Video Logo
54 people viewed this question
Top Dodge Car Audio & Video Experts
xxxxxx xxx
Are you a Dodge Car Audio and Video Expert? Answer questions, earn points and help others
