Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin
The wash cycle starts normally but when it reaches spin the drum will turn a couple of times stop then try to start to spin again.
  • Anonymous May 10, 2008
    The washer pumps then it sits for a while, pumps some more and so on. It won't spin. I suspect some blockage but we had cleaned out the lint trap and we lowered the drain hose so that it would pump into a pail. Still no spin...
  • 770 Answers
You will need to check the motor controller board for proper voltage output post your emails and I will send you the manual on how to do this
Posted on May 10, 2008
My Kenmore elite heavy duty king size quiet pak II Top Load washer stopped in the middle of the wash cycle and began to give off a burning rubber smell( I think it overheated). I turned it off and removed...
The pump is connected to the same drive that drives the tub, if the coupling is bad then the pump won't work. Does the motor start and try to run? Do you hear a grinding sound when you start the motor? If so then I would suspect the coupling is bad. this is not an expensive repair, should be right arond $100.00 to replace the coupling and you migt want to get the agitator tabs replaced as well since they wear out about the same time as the coupling. This will only add about $10.00 to the repair. The drum has to spin to pump the water out!
Nov 13, 2010 | Washing Machines
I started my machine and it started to fill and then I stopped to add a couple more things and I can't get it to restart. help
switch the power off for 1 min. then plug power back in and select spin cycle.(to get rid of the water. When all water is gone and drum starts to spin, switch off again. Select the normal wash you use all the time and see if all is ok.
Sep 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
When i turn on my washing maschine it takes in water as normal but when its time for it to spin it does nothing so it trys to take in more water and the same thing happens again then it turns it sel*** and...
you have to check the water level sensor, included to check the small hose from the drum to the water level sensor. there must be pressure from the water to suppress these sensors, the operation of the washing machine are:
washing process / cycles will start when the water level, which we set is reached. then there is pressure from the water through a hose, pressure water level sensor.
while SPIN is the reverse process of the washing process, water in the drums will be drained through the drain valve. and there is no pressure in the water level sensor so that the spin will start.
Jul 14, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer motor tries to start then stops
There are a number of possibilities but the easiest to check is if the brushes are worn down which would need to be physically checked or you could have a loose or broken wire in the motor block then you get on to the possibilities you highlighted which would require an engineer to test them.
Mar 28, 2017 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Turns off during cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Jan 30, 2008 | Washing Machines
well lets see what happens then reply to me
Jan 28, 2008 | GE WSXH208A Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
