Question about Frigidaire Kitchen Ranges
Was cooking in the oven when it made a loud pop and shut off. Checked the circuit breaker and it was not blown, then pulled the unit away from the wall to examine the cord itself and saw nothing amiss there, either. Nothing on the unit will come on including the clock.
  • Frigidaire Master
  • 17,130 Answers
You have not checked on the actual fault of the unit.The fault has occured in the power supply of the control board and it is possible that a filter capacitor has burst.SIne the clocck is not working then the power to this section has also failed. so open this section to find the actual failure of the unit which must establish the power to the clock.
Posted on Aug 30, 2010
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Samsung smh7175wc - dead??
id say there is a bad connection somewhere and is arcing due to that which is causing it to trip breakers. so when you banged it and it started it made a connection and then stopped when you turned it on. open up the back abd just pull the wires anywhere connections are made and see if any are lose.
Jan 13, 2010 | Samsung SMH7174BC Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Apr 13, 2009 | Whirlpool MH7155XM Microwave Oven
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Mar 28, 2008 | GE 30 in. JP340 Electric Cooktop
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
