Question about Car Audio & Video
Hello, i believe i have an output ic problem when i turn on my car stereo it comes on but i am not getting any sound. blew a fuse before the happened
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Did you check your speaker wiring and speakers to make sure there are not shorts first?????????//
Posted on Aug 30, 2010
  • ws_joecool Aug 31, 2010
    yes i tried another stereo and believe there is a problem with car the wiring, with the other stereo the sound just cuts in and out. shortage some where will have it look at by the electrician.
What does it mean when my JVC stereo system comes on but there is no sound coming out
The problem is in the audio output ic, "loading system" first check that the speaker wires are not shorting, If okay! the audio output ic must be changed.
Apr 03, 2012 | JVC Audio Players & Recorders
The other day i put my stereo in the car. and a stray wire hit a piece of metal and shorted out. i then got a new fuse and it still wouldn't turn on. i hit the reset button, but it didn't bring my stereo...
I've suspect that you have an open fusible resistor on the power supply section.
This component acts also as fuse to ensure the response on short circuit once the glass fuse fail to cut to avoid further damage.
Send it to repair shop to isolate the problem.This is quite fixable.
Hope that your output I.C. didn't blew also.
Thanks for using fixya.
Jan 17, 2011 | Car Audio & Video
My fuse blew in my car so i replaced the fuse. but now the deck says 'protect' now what?
Hello sir, the reason why the fuse blows up is a short circuit problem or overload on the stereo, unless the short can be find and replace the message will stay, I suspect the power amplifier IC is the bad part. have the unit checked by your dealer or an audio shop to solve the problem. Most likely those audio shop will have ideas of the problem.
Dec 11, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Stereo making speakers sound blown?
it sounds as if you may have a blown output ic.
Oct 20, 2009 | Car Audio & Video
Sony XM1002HX keeps blowing fuse
AUDIO OUTPUT TRANSISTOR OR IC IS SHORTED
Aug 24, 2009 | Sony Car Audio & Video
My RCA RS2622 sound stopped working.
I'll need to look up your specific model to be sure, but I believe that the speaker outputs come from an amp pac. The headphones are driven by an opamp IC. The outputs are blown on this. If you can solder, you should be able to repair this. I'll look up the parts required and get back to you.
Dan
Aug 29, 2008 | RCA Audio Players & Recorders
Technics stereo integrated amplifier su-g91
It sound like you have burt the output stage, for some reason, u have over driven the speakers witch blew the output ic's, or have shorted output. To check if you have shorted output unplug the speaker's and try again to see if the mesage goes away, if it doesn't open the top cover to see if you can see if there is burt resistor's or fuses, if so replace them, then try again without speakers connected, never put the volume to max, why ?????? I just don't get it. Leave the volume to 1 or 10% capacity to try thing's or with earphones this is alway's to me the best way, if for some reason it keep's burning fuses, then it is ether the power supply depending witch fuse blow's or the output amp stage, most likely if is the output amp, the two big ic's you see, check on googles with the part # on them this will tell you what they or.
Hope this helps
Bob the builder.
Feb 07, 2008 | Audio Players & Recorders
P10002 blown?
needs repair bad fets or outputs
May 08, 2007 | Rockford Fosgate Punch P10002 2-Channel...
CMT-RB5 - No Sound
your set as a problem in the audio circuit. the audio ic or transistor output needs to replaced.call a tech to do the repairs.good luck.
Apr 11, 2007 | Sony CMT-RB5 Shelf System
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
