Question about Canon Pixma iP2600 Photo InkJet Printer
Hello, i need to reset the waste pad in my canon ip2600 printer. any suggestion? thanks, Scott
  • 6 Answers
U can download at http://www.ziddu.com/download/11446869/IPTool_1.1.5.rar.html or at http://resetterprogram.blogspot.com
Posted on Aug 30, 2010
Canon iP2600 series-USB002 error message "The
You may need to reset your printer by software.
To reset your printer jast go to:Use ip reset software:
http://serviceprinter.wordpress.com/2008/03/26/ip-tool-canon-resetter/
Download canon ip 2600 printer resetter.
Run it on your pc.
And try to reset your printer with the resetter.
Thank you.
Aug 30, 2011 | Canon Office Equipment & Supplies
Ink absorber full, ip2600
I have a ip2600 that has had the waste ink absorber msg come up twice. After trying several recommended fixes involving pressing the Resume key twice then 4 times, etc., I've found the perfect solution. Start by cleaning the waste pads with tweezers, etc.
1. Press Power Off
2. Disconnect Power Cord
3. At SAME TIME, Press & HOLD Power Key while re-connecting Power cord
4. Release the Power button
5. Press the power button again
This will work!
Nov 18, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Ink absorber almost full
Hi
This issue with Canon Printers occurs when the Waste Ink absorber becomes full or sometimes due to sensor error.
To clear this error you can first try to clean the waste ink collector pads. Before proceeding please turn off your printer and unplug it from power source.
To locate these pads open the cover of the printer, move the cartridges with your hand. Now you can use a absorbent paper towel to clean these pads. These pads are on the right side of the cartridges.
After this you'll need to restart your printer. This will resolve your issue.
Daniel Scott
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I HAVE AN IP2600 WITH INK ABSORBER ALMOST FULL. HOW DO I FIX OR CHANGE IT.
Hi there with most canon priters you can reset the waste ink but I myself have not seen one for yours.
I have put a website fr you to look at click on the link it will take you there.
http://www.tradebit.com/filedetail.php/4595501-canon-ip1200-ip1300-ip1600-ip1700-ip1800-ip2200
All the Best Pineworks
Feb 11, 2010 | Canon Pixma iP2600 Photo InkJet Printer
I am getting the warning "Ink absorber full". Is there anythinh I can do on a DIY basis?
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. You can reset your Canon Printer by following this procedure—
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button 4 times for waste ink counter reset.
5) Turn off the printer.( it must be turn off) then turn it on again.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MP110 waste absorber is nearly full
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | Canon Office Equipment & Supplies
Will iP-tool.exe v.1.1.5 reset my iP2600 ink levels to 100%
Yes it does reset ink levelsas well as do several other things very well.....highly recomend the program for an ip2600
May 13, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Reset needed for Canon iP2600
Just found the answer.....
iPTool 1.1.5
for iP1200,1300,1600,1700,1800,2200,2500,2600.
http://ipt.nm.ru
You will also need RarZilla (free from the Web) to be able to unzip this download.
Jan 08, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Message code on cannon copier
You need to have the waste ink absorbers replaced, the cost of the absorbers should be around $20.00 and service is usually around 50.00. That is a very messy job, you must disassemble printer removed used/ waste ink pads in the bottom of machine reset ink counters and the reassemble printer.
Oct 24, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
How do you remove the waste ink absorber pads?
all above suggestion and solution are okey/
After opening printer best way to clean it that your hand not getting dirty wear rubberize gloves take some old injectable cyrin, suck it put into container with fine screen filter/ nothing left ink ,injection cyrin connot suck anymore .replace the pad if available or clean it /soak w/detergent wash and dry..
Jan 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma iP2600 Photo InkJet Printer Logo
345 people viewed this question
old marine
old marine
