Question about The Times Case Corporation Tractors International Harvestor
Looking for a service manual for a 1986 Ingersoll Model 648 Hyload with d-100 back hoe attachment for hydrostatic rear end
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
I can not get my wheels to unlock on my riding mower LXT 1000 Model # 917 272461
which wheels are you wanting to unlock if it is a hydrostatic rear end that you wanta unlock to push manually then in the back of the mower there is a rod that you pull out or push up & over to release the axle
Jun 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What is this black 6 inch long hoes that is sticking up/out between the rear left axle and the differential? and where do I refill and hook it back up?
Should be a vent tube for the rearend. Should hook somewhere where the brake line attaches to the rear end. Should not need to fill anything back up unless you have a leak in one of your seals.
May 12, 2009 | 1998 Lincoln Town Car
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Owners manual
Get on E-Bay and type in a company by the name of "Industrial_ Manuals". They're a real good source for air compressor manuals. John
Mar 23, 2009 | Ingersoll Rand Compressors 5-HP,...
1986 toyota landcruiser - auto box - quick chance setup kit for valve plate
Fitting an overdrive auto or a 5speed manual transmission will give a little more top end ......or..... fit larger tyres. V8 should have enough torque to cope well at lower speeds.
Jul 16, 2008 | 1986 Toyota Land Cruiser
The Times Case Corporation Tractors International Harvestor Logo
57 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
