Question about Cameras
Hello i have a panasonic vhs camcorder....well every time i turn in the camera a display message comes like dew detection warning and then the camera turns off, whats the problem?....can i solve that?
    President:
  • 2,702 Answers
The camera has damp inside it,,,,like its wet!,,,,it needs to dry out...the due warning is telling you this...just leave it in a warm place but dont go cooking it? then switch it on and leave it on till the due warning light go's off
Posted on Aug 30, 2010
Hello, my "Panasonic PV-L751 Camcorder"
Hi Sounds like there is moisture inside. Have it checked and cleaned by a repairman. Good luck.
Jun 13, 2011 | Panasonic PV-L751 VHS-C Analog Camcorder
When startup show the messaje "WARNING DEW DETECTED" and 5 seconds later shutdown
Dew warning is normal and means condensation has been detected the camera. Usually this happens when you take the camera from a warm room to a cold external place or vice versa. Wait for about an hour or so for the camera to acclimatise.
Apr 27, 2011 | Panasonic PV-L550 VHS-C Analog Camcorder
Dew detected for the PL-L750
warm it up put next to heater not to hot.. don`t leave camera in cold
May 15, 2010 | Panasonic PV-L750 Camcorder
Get "DEW DETECTED" warning on screen, powers off.
Also try this, take the bottom cabinet off, with the lcd panel facing you and the camera turned upside down and the cassette housing pointing away from you you will see 2 wide gold cables plugged into the right side of the board, realitively the same size, the gold cable that is between the main pcb and the mechanism assy is the control cable pull it our of the connector and clean it with alcohol, you can even take it one step further and evenly trim just a hair of the cable off all the way across just so that it has a new place to set. This has worked for me over 100 times in the past years. Seasoned camcorder technician 13 years experience.
chrisveal@msn.com
Aug 13, 2009 | Panasonic PV-DV103 Mini DV Digital...
Camcorder panasonic displays dew detect in red
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
Jan 14, 2009 | Panasonic PV-GS39 Mini DV Digital...
Warning dew detected will not reset
To find this information you will have to either go to the Panasonic customer support website and enter your camcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of camcorder. Ask them for help with the problem you are having with the dew warning not working correctly on the camcorder. I Hope this information helps you with your camcorder problem.
Oct 24, 2008 | Quasar VM-L450 Camcorder
Dew warnig de camara Panasonic Quasar
LA HUMEDAD CON EL CALOR ALTERA Y HACE QUE EL SENSOR DE HUMEDAD DE LA CAMARA SE ACTIVE. YO PROBE CON UNA SECADORA DE PELO DE MI MUJER Y ME FUNCIONO. LA CAMARA AHORA ESTA BUENA. HABRE EL MECANISMO DEL TAPE (CASETERA) Y SOPLA CON EL SECADOR DE PELO DURANTE UN RATO DENTRO DEL MECANISMO DE LA CAMARA TAMBIEN ALRREDEDOR DEL LUGAR DE LA BATERIA Y ALRREDEDOR DEL BOTOM ROJO REC-VHS-OFF, DEJALA HABIERTA UN RATO Y PRUEBA DESPUES PONIENDOLA A FUNCIONAR. DEBERA FUNCIONARTE CORRECTAMENTE Y SIN EL WARNING-DEW DETECTED
Jul 03, 2008 | Quasar VM-L450 Camcorder
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
