Question about Compaq Presario M2000 Notebook
Presario M2000 Wont power up with battery tried my battery or ac adapter on other laptop fired up fine tried different ac adapter also did not work. Is there a reset button or????????
I need intel presario m2000
Posted on May 10, 2008
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
May 12, 2012 | Compaq Presario M2000 Notebook
My compaq presario m2000 laptop turns off automatically. When I turn it on again it turns off after about 10 minutes.can you please help me solving the problem?
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 12, 2011 | Compaq Presario M2000 Notebook
My presario M2000 will not star orf come on. It has a new battery & power adapter.It gets very heated when charging. Helpme ???
Make sure you have an original adapter. Some of the REPLACEMENT adapters do not work very well with these computers.
ALSO make sure you have the right replacement battery. For instance in the {ressario 3000 series, there are two different batteries and one will work with some machines, but the higher level machine requires a bigger battery, although it is in an identical case.
Nov 28, 2009 | Compaq Presario M2000 Notebook
MY presario M2000 notebook will not power on.
how about the battery of the laptop, have you aleady check it? if you can find a working identical laptop like the one that try using the battery and see what happens if it will work or not, if it work then you have a battery problem and needs replacement
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook. has decent deals on these adapters.
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Presario m2000 no power
the same EXACT this happend to me! i didnt know what to do so i just a new charger at
Sep 12, 2008 | Compaq Presario M2000 Notebook
Compaq presario M2000 power cord won't charge my laptop
Check that your power adapter is working fine it may be that the power cable is broken somewhere between the adapter and the laptop. You could try another charger / adapter.
Jul 15, 2008 | Compaq Presario M2000 Notebook
Computer wont come on
well, sounds like your power cord took a dump on you check and make sure power cord light is working first i would suggest
takeing up to office depo or computer store or maybe some one you has a lap like your try the power cord on it and see if it boots up that computer or takea differnt power cord and try reboot it they sale altn. power cords for laptops (cheaper in ebay ,ubid or just type in power cords in your search engine ). i hope this helps lala linda
Jun 03, 2008 | Compaq Presario M2000 Notebook
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
165 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
